Question about Panasonic DMR-ES30VS DVD Recorder/VCR
DVD door will not open
I have changed 2 capacitors (C1209 & C1204) to 50v types which cured the initial problem of the power cutting off after a few minutes.
In removing the DVD drive to access the capacitors I damaged the 40 way ribbon cable connecting the drive to the mother board. I made an attempt to repair the ribbon cable but still the DVD door will not open.
Is there any other fault which could cause this problem ?
    Genius:
  • Panasonic Master
  • 1,550 Answers
The litle belt downside of the tray change it
Posted on May 13, 2009
My microwave has stop heating up food. What is the cause?
There are several things that can cause this:
1. Bad high power diode failure (most common and usually causes a loud humming sound when it fails initially then never heats again)
2. Bad capacitor (open or shorted)
3. Stuck Magnetron oscillator (Makes a loud humming sound when the Diode and capacitor are known to be good.) / Magnetorn failure
4. Door interlock safety switch failure. (You should hear 3 clicks on most microwaves as the door just opens or closes... if your microwave light does not come on when the door is opened you only have 2 micro-switches and only hear 2 switch clicks.
5, Main control board relay failure / main board failure.
Those are the most common reasons listed in order of usual failures. Each one of the above possible failures has a different troubleshooting procedure.
Thanks for choosing FixYa,
Kelly
Sep 21, 2011 | Heating & Cooling
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Numerous probs: 1)door won't open/close (if it does open);2)can hear (intermitently) mechanisms working when equipment is off; 3)will not detect DVD
I would suspect a weak power supply. If the power supply is not giving proper voltage, or even able to maintain proper amperage, then numerous problems will occur. One of my Ilos would take forever to come out of the "Hello" screen or open the door to load, or once you got a disk in it it would not recognize the disk. You could hear this grinding noise coming from it. Any of this sound familiar? On mine the two large capacitors on the power supply board were bad. If they are swollen then change them out. Radio Shack had them when I did mine, but most electronic supply store should carry them
Jan 10, 2010 | iLO DVDR04
Panasonic DMR-ES30V, display problem.
maybe this will help
http://www.panasonic.com.au/support/downloads/more_info.cfm?objectID=1523&fileTypeID=2&productCategoryID=51&productID=3977&listQueryString=fileTypeID%3D2%26productCategoryID%3D51%26productID%3D3977
Jul 21, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Dmr-es30v combi-vcr/dvd
Due to a design error there are 2 defective capacitors in this unit :
C1209 680µF 10volt 105°C - always fails being primarily responsible for unit's failure.
C1204 1500µF 16volt 105°C - also known to fail with great frequency.
If you have some basic electronic experience (or know someone who has). Replace capacitors C1209 and C1204 with new ones rated at 35 or 50 volts. You can get these from RS Components for around £3.00 (C1209 is hidden from view as it's located underneath the DVD drive mounting bracket. For this reason, the DVD drive must first be removed before it can be replaced). The unit should be unplugged until you can repair it. There is no alternative way round the problem, but once repaired it will work perfectly.
Apr 11, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Jan 06, 2008 | Samsung HT-X50 System
Jvc dvd/hdd recorder model dr-mh20sek
OK changing the caps only resulted in proper filtering and voltage smoothing and did very little to solve your problem. Now what swollen caps are a sign of is an over voltage condition. what I would suggest because you may have a bad voltage regulator, is that you have to get a schematic and measure the voltage levels on the power supply to determine if they are correct or not. This will tell you if the regulator is bad or not. You do have a power supply problem you just have to determine where in the power supply. This can be done with the schematic and a voltmeter.
Sep 17, 2007 | Televison & Video
Panasonic DMR-ES30VS DVD Recorder/VCR Logo
211 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
