Question about Canon SmartBase MP360 All-In-One InkJet Printer
Wont print text does still do photos, the cleaning of the nozzles dont work either
  • frodo01 May 13, 2009
    Thanks for the reply got enough ink and the software the problem i think was me using cheap ink
    Sergeant:
    Champion:
  • 201 Answers
Do you still have any black ink left? try doing a copy, check your printer drivers
Posted on May 13, 2009
Printer wont print in colour
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Sep 05, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Only prints black ink text; cartridges full and good.
Run head cleaning and deep head cleaning for few times. If it doesnt help, you can try to remove print head, and clean the nozzles with distiled water.
And after that also run few times head cleaning mode.
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
May 27, 2010 | Canon i860 InkJet Photo Printer
Canon MP830 Will not print black text I have cleaned printer head with steam and nozzle rocket, cleaned purge pads and reset the waste tank - what can I do next???
Try to set/change the Media Type from Plain Paper to Photo Paper Plus Glossy and print your text with plain paper.. perhaps it would solved your problem. i had the same problem but after done that way. i can print with the black ink, but only after i set the media type become photo paper... (bad English)
May 25, 2010 | Canon Office Equipment & Supplies
Photos print with a faint 'pinstripe' effect
that could be head alignment (most noticible on low quality settings .. there is a procedure for aligning the heads ... or it could be clogged nozzles
to check these things start to print something
then select preferences .. then maintainence then
you have a choice .. nozzle check should be done first .. if all nozzles are working then go to "head alignment" and follow instructions there .. if some nozzles are not working then run the "cleaning" utility . sometimes it needs to do that several times .. if you cant get all nozzles working then you can try "deep cleaning" that uses lots of ink so you dont want to do that often ... if that doesnt work then you need new heads .. the heads in many pixma printers are easily replacable but costly ..
if all the nozzles are working and head alignment was done but you still have faint lines then try "high quality mode" .. in that mode you should not see any lines ..
Dec 23, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
My photos have a stripped background, but documents print perfectly. Can you help? I have done all the cleaning, alignment, etc.
Run Nozzle Check first. Is the nozzle perfect?. Usually little unperfect nozzle pattern does not make significant effect on text quality but in photo quality it does.
Nov 29, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Text is printed in B&W correctly but photo print only in one color - jellow
Check nozzle. It must the cyan and magenta are clog. Do head cleaning. Check nozzle again.
Sep 19, 2009 | Epson Office Equipment & Supplies
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
