Question about Compaq Presario V4000 Notebook
Keyboard not working
I took the keyboard out because it stop working and since then it has not worked
  • 4 Answers
Re: keyboard not working - Compaq Presario V4000 Notebook PC Laptops
Maybe replace the keyboard?
Posted on Oct 15, 2007
0 characters
3 Points
Keyboard stopped working, animal stepped on it.
Check the Num Lock key is not activated. If it is, press it to release it or you may have a jammed key.
Mar 05, 2014 | Dell Inspiron PC Laptops
T button stopped working
The keyboard is broken, so it is time to replace it.
Feb 17, 2014 | PC Laptops
Hewlett packard manual
Have you put the battery back in the laptop? Your laptop probably just needs charged. When it blinks it means it needs charged. Is the battery in the laptop correctly? Try putting it on charge. Hope this helps.
- Nathan
Jan 16, 2014 | PC Laptops
The cap lock.shift,tab and the 1,2,5,8 and the delete keys stopped working. Also when I took off the tab key,it will not stay on now. Help!
disconnect and reconnect the keyboard from the systemboard. if that doesn't correct the problem then time for a new keyboard.
Dec 17, 2010 | Samsung PC Laptops
Laptop keyboard not working when LED Power board is connected.
chances are there have been short circuits on the keyboard controller. better bring it to a service center
Jul 07, 2009 | PC Laptops
My acer aspire 3680 lost it's keyboard! The mouse works fine but the keyboard doesn't do anything, it's like it's not connected. Can you help
odd. go to thh control panel-- then system-- hardware--device manager
check under keyboard-- is it there? (you can do all this with the mouse)
I ask because if a part of the computer stops working, it usually gets a yellow ? mark in front of it in the list. what you can try is to "remove" the keyboard if you see it-- it will not really do it, because on reboot, it will reload your drivers again-- remove or uninstall the keyboard in the device manager, then reboot the computer and soo if the reloaded drivers fix it.
if not, it may be hardware failure. windows has plenty of drivers in it to drive any keyboard-- you dont need anything special, so there's no mystery download that your missing.
can you call acer and see if youre under warranty? you may need to send it in. dont forget, you could always buy an external keyboard for 15 bucks to plug into the back to tide you over until you're ready if you need to send it in for servicing...
Feb 03, 2009 | Acer Aspire 3680 Laptop
Keyboard keys non functional
you can reinstall the (Toshiba HOTKEY utility)... i think this will solve the problem
Feb 05, 2008 | Toshiba Satellite A45-S150 Notebook
Compaq Presario V4000 Notebook Logo
96 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
