Question about Timex Ironman Triathlon 51931 wristwatch
Screen goes blank
When i press speed/distance display button the screen goes blank from 10-45 seconds. also sometimes when the mode button is pressed the screen goes blank for 5-15 seconds. the watch is keeping the time and date correct and the screen is nice and bright
  • 2 more comments
  • Anonymous Nov 13, 2007
    I have the same problem!!! please help
  • Anonymous Jan 16, 2008
    I HAVE THE SAME PROBLEM!
  • FlippedGator Apr 10, 2008
    I just bought T5E671 Body Link Ironman off Craigslist.
    Still in original packing....It works great for running,
    but when I press the INDIGLO button or set night mode , which also engages the INDIGLO, the screen goes blank.
  • Anonymous Apr 01, 2014
    My new watch is flashing but no numbers just a blank screen every 10 seconds?
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Posted on Apr 13, 2008
I need to know how to set my skmei watch 0955
  1. Continue to press the MODE button until the second digits blink.
  2. Click the START button to reset the seconds to zero (00).
  3. Press the RESET button and the minute digits will blink.
  4. Click the START button to set the minutes. Hold down on the button to increase the speed.
  5. Press the RESET button and the hour digits will blink.
  6. Click the START button to set the hours.
  7. You can select between 12-hour and 24-hour display modes. A "P" indicator signifies it to the afternoon 12-hour setting, a "A" indicate in the morning and a "H" means that it is the 24-hour setting.
  8. Continue this pattern to set the day of the month, month, and day of the week, respectively. 9 Press the MODE button to finish and exit.
Feb 20, 2014 | Watches
Watch Manual for Sergio Valente model# F-IAGAG
These are operating instructions for an SV F-IAGAG (Sergio Valente) watch.
There are four buttons on the watch.
A: upper left
B: lower left
C: upper right
D: lower right
Pressing A turns on the watch face backlight.
Pressing B changes the mode.
From the normal time display mode, one press of B enters the stopwatch mode. In this mode, pressing C will start the stopwatch time count. Pressing C again will stop the count. Each additional press of C will start/stop the count. While the count is proceeding, pressing D will freeze the display of stopwatch time, yet the count will continue. Pressing D again will cause the display to begin updating with the running count. Each press of D will freeze/unfreeze the display update. When the count is stopped (with a press of C), pressing D will reset the count to zero. From this mode, press B again to return to time display mode.
From the normal time display mode, two presses of B enters the alarm time set mode. In this mode, either the hour or minute portion of the time display will be flashing. That which is flashing can be changed by pressing C. Pressing D will switch to the other portion (hours or minutes). Any time the alarm mode is entered and a change is made, the alarm is set to "on". This is indicated by a check mark in the circle display next to the "9" on the watch face. The alarm can be toggled "on" and "off" from the normal time display mode by holding down button D and pressing button C. Return to the normal time display mode by pressing button B while in the alarm time set mode.
From the normal time display mode, three presses of B enters the time set mode. Upon first entering this mode, the seconds display in the circle near the watch face "3" will be flashing. Pressing button C will reset the seconds to zero. Each press of the D button will advance to a different value field for adjustment. The field of adjustment will be flashing. The sequence of fields is (seconds - minutes - hours - date day - date month - date day). Pressing C will change the value. When adjusting the hours, both 24hr format, and 12hr AM/PM format is available. Each press of button C will advance the hour value. The sequence of 24hr format will be indicated with an "H" in the "seconds" circle (near the watch face "3"). After hour value 24 of the 24hr format, the next hour is a "12" value, with an "A" in the seconds circle. Twelve presses of button C will step through the AM hour values and present an "12" value with a "P" in the seconds circle. Twelve more presses advances through the PM hour values and returns to the 24hr format. Pressing button B will return to time display mode.
Pressing button C while holding down button D will toggle the alarm "on/off" state. The "on" state is indicated with a check mark in the display circle next to the "9" on the watch face.
Jan 08, 2012 | Watches
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Dec 20, 2010 | Watches
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
Resetting time on relic watches
Press and hold the Mode button - upper left. At first, it will display the stopwatch function. Keep holding until it goes to flashing alarm set mode. Once it starts flashing, release the button and then immediately press it again and release it (do not hold it the second time). Now you are in time set mode. You can change the time, starting with the seconds, by pressing Adjust - upper right. You can move to minutes, hours, day, and date by pressing Alarm - lower right. Pressing Mode again will exit the set function.
Jul 09, 2008 | Watches
How to set watch
I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
Apr 02, 2007 | Kenneth Cole RK5034 REACTION
Timex Ironman Triathlon 51931 wristwatch Logo
1,232 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
