Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Food stays frozen regardless of temperature setting
WE just bought a house and the refrigerator a Frigidaire model # FRS26H5AS( 5 years old ) has the annoying problem of keeping everything frozen on the right side of refrigerator regardless of temperature setting. Even at setting 0, it remains freezing. Can you help us out?
Thanks for any suggestions.
John
  • jafa777 Oct 15, 2007
    Is the vent supposed to move back and forth freely ( it`s not moving ), or do I need to replace the damper motor if the vent is stuck in the open position?
    Thanks.
  • 473 Answers
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
  • Craig Shelton
    Craig Shelton Oct 15, 2007
    It is a motor that moves according to the position of the freezer control.  The colder you set the freezer the more shut the damper should be.  The warmer the freezer setting the more open the damper should be.  It may not respond in movement as soon as you adjust the freezer temp. but should within a 1/2 hour give or take.  Adjust the freezer to the coldest temp.  Wait a little while and see if the damper closes.  If not I would say the damper is bad.
How do I change temp readout from c to f on a refrigerator frigidire that is 10 years old model FSC23F7DSB
Hello Joel, thank you for your post!
I understand that you would like to change the temperature readout on your Frigidaire refrigerator, FSC23F7DSB. In order to change your temperature display you need to hold the fresh food arrow up and then press the freezer up arrow 3 times within 5 seconds. I hope this information is helpful. -OOS
Mar 18, 2015 | Frigidaire Refrigerators
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I bought a model FRT18B5JB2 in August 'o9 to put out in the garage for extra cooling and freezing room This winter the freezer is not keeping items frozen. They are no thawed completely, but they are not...
Refrigerators do not work correctly in the winter in unconditioned space.
It is too cold for the unit to run normally.The compressor oil gets sluggish and strains the compressor when it does run.
The thermostat never warms enough for the unit to come on and run.
Therefore the temperatures in fresh food and freezer stay at the top end of the set point. This would cause about 42-43 in fresh food and around 18-25 in the freezer.
In the spring time it should start running correctly again.
Feb 14, 2010 | Frigidaire Refrigerators
It runs to much
1) Are the temperature readings you give measured with a thermometer, or just the temperature settings you set the freezer and refrigerator for?
2) Ice cream "stays frozen, but not hard", I'm not quite sure I understand you point. Ice cream will usually stay solid enough in a refrigerator/freezer to be easily dip able. Frozen hard is not normally good as you can't dip it. Please confirm what yu are wanting.
Dec 10, 2009 | Frigidaire Refrigerators
Ice maker working very slowly; as else working fine
Change the water filter if it is 4 to 6 months old.
Jul 29, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23H5SB6 side-by-side freezing food
It sounds like the fan in the freezer behind the rear panel is not working. You should be able to hear it. It won't run with the door open so hold the door switch in.
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Frozen food in fridge
Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
Mar 29, 2009 | Frigidaire FRT18G4A Top Freezer...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
648 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
