Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have got a Craftsman model 917.270821 19.5 electric start 42" mower and cant get it to start I have replaced the starter and had the battery checked and all is good there, but dont seem to be gettin
I have got a Craftsman model 917.270821 19.5 electric start 42" mower and cant get it to start I have replaced the starter and had the battery checked and all is good there, but dont seem to be getting any power to the starter What can I look for next
  • lizzyeggs
    lizzyeggs May 13, 2009
    I'll try anything right now TY for your help
    Sincerly
    Brenda
  • 351 Answers
Check the wires from the back of the ignition and also the small wire that connects to the starter, if you get a 12v test light check each wire individually by holding the test light on the wire and have somebody turn the key, the test light should come on if the power is going through the wire.
If there is no power the ignition may need replacing
Posted on May 13, 2009
  • m8200n
    m8200n Jun 04, 2012
    You also very likely have a 30 amp fuse in - line ... check that. It's in the wiring harness behind the engine
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 04 ,42 inch electric start riding mower will not start its not the belts or the starter or battery. model # 917.275371
not much to go on. is it getting gas? is it getting spark? is the gas turned on? some have a fuel shutoff under hood.
Aug 06, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hello - I have craftsman 42 inch deck mower with a kohlar engine that does not start. Battery appears fine, when I turn it - it clicks with the head lights turning on. Ang ideas on how to get it started?...
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding lawn mower will not turn over.
Check to see if there are any safety switches on the seat that may have gone bad and aren't allowing for it to start. Also check the clutch. Some mowers require it to be depressed in order for the engine to turn over.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
857 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
