Question about HP Scanjet 4370
Scanned save locations
How do I tell the scanner software to change the default file save location from the "My Scans" to a different folder?
  • 1 more comment
  • bardkin Oct 14, 2007
    hp Scanjet 4370
  • bardkin Oct 15, 2007
    I do not have either of those options. If I use the front side buttons on the scanner, the only option I have is to manually choose the destination each time I scan. I have to scan several single page docs each day, and I have looked through all the software I have and have not seen anything that will let me change the default. I have tried the HP Image zone and the page that comes up for saving the file ( save file type ( .jpg; .rtf; etc. ) and the file location.) But it wont let me change the default file location to anything other than the my documents / my scans.
  • Anonymous Mar 27, 2014
    After scanning a file to batch when I save the file names are adding "Pri" at the end of the file. Where can I turn this off?
  • 1,006 Answers
Go to settings or options and there you can change the location
Posted on Oct 14, 2007
Scanning - When I scan a photo, how can I then access it. I have Picasa 3 software
When you scan a photo or document, the computer will need to save the new document somewhere on the system. You should determine (before the scanning process) where that document is being saved and what name it is being given.
Jun 23, 2016 | Epson Office Equipment & Supplies
How do I change the "output" from my scanner to a file so I can attach it to an e-mail
Usually scanners save to a folder inside THEIR file installed in c:\Program Files by default.You can look for pictures in there and drag them to a file you create where you want.
For future scans,when the scanner saves the file,open it and "save as" to the folder you created.
Aug 10, 2010 | Canon MX700 Office All-In-One InkJet...
Scanner appears to work but cannot find the location of the scanned document
Check the software settings to find the default location of the scans - especially if you only used the scanner software. Otherwise, do a windows file search of the document if you saved it. If you used an office program, it will be easier to find.
Jul 08, 2009 | HP PSC 1410v Printer
Please tell me how can i tvansfer many pictures(for example 6)fro
You need to specify the path in the settings of scanner which is called the default location or path.
But at a time you can scan and save picture in a single folder only. but after that you can cut and paste that file in another folder.
Jan 13, 2009 | HP ScanJet 3670 Flatbed Scanner
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
Scan copy to computer
Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
HELLO
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
Jun 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson
I know the error is on the printer but it may still let you scan.
Jun 06, 2008 | Epson CX8400 All-In-One InkJet Printer
Hello, I have a new Canon MP 610 all in one printer/ scanner/ copier. I have installed the software, downloaded drivers. It prints from the PC, makes copies, but it will not scan and save to PC. HELP !!...
in the printer control panel, you can set how the scanner handles the image. You'll need to tell it where and how to scan/save to pc, including folder location. Defaults are usually some obscure file type
Apr 24, 2008 | Office Equipment & Supplies
HP Scanjet 4370 Logo
389 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
