Question about Dell Computers & Internet
Can u direct me where to learn red hat shell scripting?
I want to learn how to write shell scripts in red hat linux
    Novelist:
  • 153 Answers
At a terminal type:
man bash
this will bring up the manual for the bash shell.
There are a lot of good examples throughout the system of well written shell scripts, and /etc/init.d is full of them.
Google bash shell scripting tutorial.
There is info galore on this subject.
Posted on May 13, 2009
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
I want install tata photon+ in linex
hi...
many mobile phone companies don't provide drivers for linux.
But there is a software i would personally recommend to you. Actually its not a software, its a shell script.
Name of the software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
  • connect to mobile devices by IR, bluetooth, USB Cable
  • Send and receive files between computer and device
  • Access Internet from Device by Dial Up Networking
  • Browse files on Mobile device
  • Mount the mobile device on a user specified mount point or communication port.
  • usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
  • Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  • ability to connect to any locked/unlocked USB Internet Modems (Zero Devices)
fully automated connection setup. No manual input is needed except to specify connection name.
http://www.sakis3g.org/versions/latest/i386/sakis3g.gz
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Feb 17, 2011 | Red Hat Enterprise Linux ES 3 Standard...
What can window does it take
I have loaded windows 2003 server on this but the following OS are supported:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279705&lang=en&cc=us&prodTypeId=15351&prodSeriesId=316537&taskId=135
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows Server 2003
Novell NetWare 5.1
Novell NetWare 6.0
Novell NetWare 6.5
OS/2
Red Hat Enterprise Linux 2.1 (x86)
Red Hat Enterprise Linux 3 (x86)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Linux 7.2
Red Hat Linux 7.3
Red Hat Linux 8.0
SCO Open UNIX 8
SCO OpenServer 5
SCO OpenServer 6
SCO UnixWare 7
SUSE Linux Enterprise Server 7
SUSE Linux Enterprise Server 8
SUSE Linux Enterprise Server 9 (x86)
Dec 25, 2010 | HP Compaq ProLiant ML350 G3 Server
UPDATES for Asus Eee PC Series 2G Surf
Hi i'm Rain.
Ok i need to know is that the Red hat based Linux or Or is that more compatible to the Father OS Unix.
I Have a list of commands everything from changing a User names thru Linux to By passing the XP Adminastrator passwaord .
Xandros is just a Updated Of Red Hat if i'm correct and im sure i am .
Make sure you have full administrator rights!!
Next you will need to type . Sudo usermod -g admin user
I assume you do have Sudo Access . The command will give you rights . But still like i said i need the other information.
Nov 03, 2009 | ASUS Eee PC 2G Surf Notebook
Hw can i access internet through idea usb net setter on rhel 5.1
i dont think i work on red hat,i saw on huawei website
  • GSM/GPRS/EDGE (850/900/1800/1900MHz)
  • Support 236.8Kbps high speed services
  • Support SMS and Voice (Optional) service
  • Plug & Play
  • Data statistics
  • Support Windows 2000/XP/Vista and Mac Operating Systems
Sep 19, 2009 | Red Hat Enterprise Linux ES Basic Edition
GRUB PROBLEM on clone pc with Red hat linux 6.0
Boot up from Installation CD/DVD and type 'linux rescue' at boot: prompt, This will drop you at 'shell' prompt.
execute this
chroot /mnt/sysimage
cd /boot/grub
less grub.conf
less device.map
post the contents of device.map and grub.conf files ( first title, root and kernel lines of grub.conf ).
Apr 03, 2009 | Red Hat Enterprise ES 4 for Linux
Linux
A shell script is a plain text file that contains instructions for a Unix style shell to run. The most common shell on Linux is BASH.
e.g. a minimal example
#!/bin/bash
# script that says hullo
echo "Hullo world"
(you would normally do _much_ more than that.)
By the way most Linux distros have easy to use tools to set up modems (dialup and pppoe). Or you can usually access the modem/ADSL router directly through a web interface. (see the documentation that comes wioth your modem. (you wont need those silly disks you got with your ISP account :)
Jun 30, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
