Question about Intel Motherboard
Recgonize and list common problems associated with system modules(motherboards,power supply,cpu) and their symptoms,closely study the cmos,blos settings and suggest how to troubleshoot problems such as post error codes
  • 52 Answers
When you on th comptuer one post beep appear, if there is long pause beep is hear then there is error on ram, and if there is long beep is hear there is error in CPU, it may in over heat
thanks
ok byee
Posted on May 13, 2009
When i on my PC desktop, go into the windows, my PC will close and then restart, then close then restart? what's the problem?
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
This compound is an inexpensive solution and can be found at any local Radio shack or computer repair center
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Jul 09, 2012 | Computers & Internet
Please clear cmos if system no display after overclocking
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
Mar 25, 2011 | Biostar G31-M7 TE Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
The button to turn on/off doen't work.
What is the motherboard and computer brand/model if it is branded?
The on/off button not working could be a few things. Here is the short list in order of most common:
Bad Power Supply
BIOS problem/CMOS needing to be cleared
Damaged Power Button
Bad motherboard
Bad CPU
Please reply with any additional information and troubleshooting you have done.
Feb 22, 2010 | Computers & Internet
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Sep 15, 2008 | Computers & Internet
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
NFORCE3-A Won't post with 2 sticks of 512MB DDR RAM, only if 1 stick used :-(
U cannot use 2 identical DIMMs of RAM Memory, find two same and faster, couse 233 or 300 is too slow for nForce3 motherboard.
Aug 30, 2007 | EliteGroup nForce3-A Motherboard
Mach Speed V2DP Motherboard
If you can, could you check your cmos battery, to see if it's flat. then come back. Some boards need the battery to even boot not to just hold bios sttings. You also have to bear in mind if the proccessor isn't working it will go no further than power up. Also, removing cmos battery doesn't clear cmos on all mobo's, you have to put jumper across pins 2-3 on JBAT1 terminals and then back to pins 1-2. Why did you need to clear the cmos; have you done any upgrades?
Oct 13, 2006 | Mach Speed VENOM V2DP Motherboard
Intel Motherboard Logo
296 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
