Question about Nokia N95 Smartphone
" no bluetooth device found"
I have purchased nokia bluetooth device bh209 for my n95 8gb , but it fails to pair. phone displays " no bluetooth device found". i have followed the procedure given in the device booklet. my phone has updated firmware 30.01 bluetooth device is working properly as it starts flashing LED , but the phone did not respond
bamma_boy
  • 146 Answers
SOURCE: Palm T3 - Nokia 3230 Bluetooth problem, will dial from T3's address book only once.
try setting ur palm phone as AUTHORISED in 3230 bluetooth device list.
Posted on Jan 25, 2008
  • 8 Answers
SOURCE: NOKIA 6708
try buyign a new batterie
Posted on Jun 25, 2008
saranathrana
  • 32 Answers
SOURCE: cannot receive data using nokia 3110c bluetooth
replace the bluetooth ic.
Posted on Aug 20, 2009
SOURCE: my nokia bh 213 bluetooth was working with nokia
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
Posted on Mar 22, 2010
halbrook
  • 560 Answers
SOURCE: phone blocked whilst trying to flash firmware
You need to bring your unit to cellphone technician. They have special cable for connecting dead units to a box then to computer and reload the firmware. the cable and box are very expensive and not advisable for 1 time use.
Posted on May 10, 2010
How do I pair my nokia 3109c mobile phone with my motorola h720 bluetooth headset - it just keeps saying "failed" when I try.
Hi Sue Clay,
Please use the following link to access to the user manual of your H720: http://bit.ly/1DyhSmE, on page 5 you can find how to pair the device, if the "failed" message continues, use the instructions on page 13 to reset the device.
Regards,
Lester S.
Motorola Support
Oct 27, 2014 | Motorola Mobility H720 Bluetooth Headset
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How to configure or pair my motorola T305 car bluetooth with my mobile nokia E63
First step:From your nokia e63,scroll to bluetooth goto paired device and click on add device after that,then pick up your bluetooth and press down the power button make sure you did not remove your hand from the button until it displays on your phone.
Second step:After your phone has found the device,click on the device from your phone and you will be ask to type a password which the password is 0000.enjoy
Jan 30, 2011 | Motorola Mobility T305 Bluetooth Speaker...
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Im trying to pair my verizon cell phone to my motoral headset
6) You will be required to enter in a pass code which is standard ‘0000’.
Hope this helps
Chris (ziraffa)
Nokia 6500 will not pair with Parrot ck3100
5) Select the Parrot device and click add
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
GE Bluetooth connectivity
5) Select the Explorer 3XX device and click add
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | GE Bluetooth In-ear Headset Wireless...
Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
Nokia N95 Smartphone Logo
78 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
phil
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
