Question about Creda W100FW Front Load Washer
I need to find a water pump for a washing machine.the brand is simplicity the model # is kwm573w-1109. there was also a second model # on my machine # sew3650 not sure why. its a 2 speed heavy duty washer made in Guelph Ontario Canada.its about 12 years old. thanks
  • 144 Answers
Where are you from? If you take the pump out you can proberly find a generic pump motor that will fit the housing from your original pump. Alot of other brands use the same pump motors with a different housing. Maybe take the pump to an appliance repair shop to see if they have one that fits. I have a very large box of all different universal pump motors if I saw the pump I could find one to fit. You'd want to check that the watts and voltage are the same though. Cheers
Posted on May 13, 2009
I need the instructions for Simplicity pattern 1109. I lent the pattern and it was returned without the instructions. Can you help please?
patterns pretty much follow the same steps, find one that is close and see if that will work for you, same company, same style of outfit.
Sep 19, 2017 | Simplicity Sewing Machines
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
My fisher and paykel top loader washng machine is bloked and will not Rinse, drain and spin. Mainly Drain as im pretty sure its blocked from fluff etc nybody can plese tel me how to unblock it? Thanks
The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
Apr 10, 2015 | Fisher and Paykel Washing Machines
No water entering machine
In order to help, I will need your brand and model number so I can see your unit as you do. There are many machines out there and they are all a little different. To offer more professions assistance, please reply with the model number and brand of appliance.
Waiting to hear from you,Eric Campion
Mar 22, 2012 | Washing Machines
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Blocked drain
Is there still water in the machine or have you bailed it out? Some units have a serviceable water pump, meaning you can take the bottom of the pump off and clear gunk that has plugged it up. When you manually turn the dial to spin cycle, does it spin and push any water out even a tiny amount at a time? If not, take a large bucket and then place it on the floor next to the machine and place the drain hose in it. The bucket needs to be lower than the water level in the machine. When you do this, does it drain? If so this would solve the issue of whether or not the pipes are plugged. If in both cases either on spin or with the hose lower than water level, if it only drains a tiny stream then you do have a plugged line and you would need to disconnect the hoses from the pump under the machine and clear the plug. Be prepared for a lot of water to come out when you take the hose off of the pump. The plug is most likely in the hose coming out the bottom of the tank going to the water pump. This item has the hose leaving the machine going to the house drain. The other large hose goes up to the bottom of the tank. Good luck and let me know if you need more help.
Feb 03, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
91 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
