Question about Mitsubishi WT-46809 46" Rear Projection Television
The screen looks like it is 3D I have a couple of issues. #1 the picture bends in the middle. I have to wait for the tv to warm up or turn off the tv for it to go back to normal. #2 the picture is faded. I have to play with the cords in the back of the tv until the picture is vibrant.
  • skeets1129 May 14, 2009
    Hi Guru:
    The TV is connected to an external audio source (Logitech Z5500 speakers) with the sub-woofer residing on the floor and the speakers on top of the TV. I also have a Bose wavefront/alarm on top the TV as well. However, I only use the external audio system for watching DVDs.
    This TV (Mitsu WT-46809) was purchased brand new back in 2001 and I have only moved it once (from my old address to my new address).
    Let me know if you need any other information from me.
    Thanks,
    Steve
    Novelist:
  • 130 Answers
Its a board error in the tv.as the solderings on the board are got loose .after sometime when the board gets heated up the solderings become firm and the tv works. now why after getting warm the solderings becomes firm ,this is because.actually there is spray that is applied on the board to keep the solderings firm and tight.after some time in many tv the spray gets dried up and solderings becomes loose.after getting warm the spray melts a bit and due to that it again gets the firmness which the soldering joints require. so just get your whole board dry soldered at any local tv shop.they have this machine for dry soldering.in that they will apply the spary again. this will help. please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 15, 2009
    Brigadier General:
  • 3,917 Answers
Is the TV sited by a speaker or other magnetic device. Magnets cause this sort of problem. Can easily be shown by putting a magnetised screwdriver close to the front of the screen.
Is this an old tv? When I worked in the trade I used to regularly gave to take a degaussing machine out to the home and run this over the set.
Thank You
Posted on May 13, 2009
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
3d look with little bending in bottom left corner of screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Hitachi 52LDX99B 52" Rear Projection...
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Kpr-46cx10 picture issues
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Mar 05, 2010 | Televison & Video
Sony 46 inch proj tv picture is bowed in the middle and color is
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture is bending at the top and bottom and looks 3d
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Convergence issue
Not sure how service menu will help you other then to do more adjustments such as 3D reform and such. Not real sure, just a long wild guess but the coils on the picture tube could possible be loose enough to change positions when heating up causing picture alignment to change. Might be a cheap service call.
Apr 23, 2008 | Sony KP-61HS10 61" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
