Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error Code c1188
Code c1188 after warming up
    Sniper:
  • 62 Answers
I've not heard of C-1188 before, it's not listed either. However, any C-11xx codes relate to the finisher. It's worth opening and shutting the finisher, plus have a look inside it for any stray bits of paper
Regards
Taminol
Posted on May 27, 2009
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
How desbloquear un gfive c1188 olvide la clave
IF you forgot the pin code. You can push the menu button and then enter the security code which is 000000 unless you changed that code as well. If you forgot the security code as well then you have to have the phone reflashed to reaccess it.
Mark
Motorola Support
Apr 29, 2014 | Motorola Mobility RAZR V3
Se me bloqueo el gfive c1188 y olvide la clave y no se como desbloquiarlo,
Sep 09, 2013 | Motorola Mobility RAZR V3
2000 Oldsmobile Sillouette idles rough when warm
Why don't you get your ride check for engine error code? Getting the error code resolves almost every problem. Please update your answer with the error code you are getting (if any).
Jun 26, 2013 | 2000 Oldsmobile Silhouette
Error code SC 542
This is a generic answer, as you didn't state the model machine you had. In general, this is a fusing error code; hot roller is not warming up, or not warming up fast enough...
SC542 - Fusing temperature warm-up error
The fusing temperature does not reach the standby temperature within 20 seconds after the main switch is turned on.
Causes:
• Fusing thermistor defective or out of position
• Fusing lamp disconnected
• Fusing thermostat open
You will need to enter into the service mode in order to clear this service code...
Dec 18, 2009 | Ricoh Office Equipment & Supplies
CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Mar 27, 2009 | Canon imageRUNNER 5000 Copier
Error code SC542 on a Ricoh 3245
Hello, this code is : Fusing temp. warming-up error. This means that the fuser did not warm-up in the allowed time. Possible causing-- in order; Thermistor bad or out of position,
fuser lamp bad,
thermofuse bad,
BICU board defective,
power supply board bad,
poor fusing unit connection ----check this first if you had the fuser out of the machine.
If you would like to talk, I can see if we can try to reset the code -- sometimes if the machine is to cold at warm-up the code will throw. # 216-701-1591. Thank you.
Jan 12, 2009 | Ricoh 6513 Copier
Error Code SC542
Fuser temperature warm up error. Hot roller warm up error. It could need a new thermistor or a heat lamp. That will make the error go away.
Oct 10, 2008 | Ricoh A1515F Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
97 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
