Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 46in Rear Projection TV Model#46H83
When I turn on the television it won't come on at all, the red light just flashes and there is only a clicking sound.  A repairman can out and said the power supply board and the power deflection board needed to be replaced for $350.00 dollars.  Is this true?  Also he took the board out of the tv and now two weeks later after several dozen unanswered calls and no show appointments, I do not have a tv.  Can I call someone else and have them replace the power supply and deflection board? Was this really the problem?
  • Sammy Jo Nov 06, 2007
    We were watching the tv one day and the picture collapsed to the middle and went black. The red power light was blinking and the tv itself was making a clicking noise. The 1st repair guy said it needed a new transistor..he ordered one from Toshiba, it worked for 2 weeks leaving a pink line in the middle of the picture (repair man said it was because the bulbs burned that line there when the picture collapsed). I called them back out when it went out again and they put in another transistor thinking the 1st one was defective. (these took 4 weeks to get by the way). Again, worked for 2 weeks then went black again. Called Sperry TV out and they said another part needed to be fixed. They ordered it, when he put it in, something blew and he said, "I think the other repair main sabotaged your tv." Sperry ordered 3 parts thinking this would solve the problem and it didn't. He now says they need to take the tv into their shop, do a probe (which will cost me $159 even if they can't fix it), and then go from there. Metro, the 1st repair place, said I needed to replace all the bulbs for it to be fixed...the 3 big bulbs in the tv which are about $250 each. I don't know who to believe, I think one of them ruined my tv when it could have been a simple fix, and now I don't know what I should do. When I bought the tv it was almost $4000.00 so I kinda feel like I should pay to have it fixed instead of buying a new one...what can I do?
  • 375 Answers
Sammy jo ,you burnt the tubes by leaving it on with a vertical collaspe faultmnow you have three damaged tubes,i also think that you also have a bad yoke which is taking out the new parts ,the cost is within reason,the shop repair is to insprct it deeped for possible other faults and damage already done.
Posted on Dec 16, 2007
Apple tv has no sound on my toshiba 46h83 tv
How are you connected and in what way? You should be able to rule the set in or out:
First: does the set have sound with only a DVD player connected to a rear input?
Second: are the speakers turned to OFF in the main menu?
give as much information as you can so I may be able to help.
Dec 10, 2012 | Toshiba 46H83 46" Rear Projection...
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Nov 14, 2008 | Toshiba 46H83 46" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
