Question about Samsung SyncMaster 152 B 15" LCD Monitor
Samsung 945NX LCD PC Monitor - whole display is of reddish
Im using Samsung 945NX LCD PC Monitor. I rebooted my pc when it came up the whole screen was of reddish. I plugged out VGA Cable cleaned and plugged in but it didnt help me. Also tried reset option in the monitor which also failed.
Then I updated Intel D945GCCR mobo BIOS and NVIDIA driver to latest version but still the problem persists.
Pls help.
  • 3 Answers
Replace the monitor
Posted on May 13, 2009
  • msnavalgund May 13, 2009
    Replace the monitor
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
Horizontal static line screen
Your screen is going bad. To verify that it's the screen try connecting another monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker an connect it to the computer. If the Borrowed monitor displays ok without the line on the screen then your lcd screen is bad and your video card inside the computer is good. If the Borrowed monitor displays the same line as your lcd screen then your video card inside the computer is bad.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 27, 2012 | Samsung NP-X460-WS02US PC Notebook
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
I'm getting no picture on my monitor, all connections are good. The pc is hooked up to the tv on a seperate cable and I can use the pc on that, just not my samsung monitor.
try to reseat the cable. also, use a different cable and check if it still doesnt display anything. then lastly, try using your samsung lcd on a different system to determine if it's good.
Dec 03, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
No display blinking power led on cold boot
I think a capacitor on PSU board has popped.. Check it. replace it for a $1.00 part
Sep 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Whole display is of reddish colour -Samsung 945NX LCD
try to update the lastest version of your video card driver
May 12, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
RM / Samsung GT9000 LCD problem
1of to2 suggestions it mite be the display or it mite be the driver card, try pluging it in a other display and see if it
reboots up if so driver is good and it is the monitor bad. lala linda
Jun 06, 2008 | Computers & Internet
Samsung Monitor image rotates 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Mar 27, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
External monitor
Try going into cmos and enabling multi display (external)
Also u can boot into safe mode and restore windows to a previous day
Next u can save your file on a flash drive then reinstall windows
Hopw this helps ... u also have an s video port
thanks
jaywizz
Nov 18, 2007 | Acer Aspire 5500 5570-2609 Laptop
Samsung SyncMaster 152 B 15" LCD Monitor Logo
196 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
