HDD Not detected - Computers & Internet
  • pickitfence1 Sep 20, 2009
    i have an older dell dimension 3000 i bought it brand new in 04 it remained in the box for two years it was a computer that i got a deal from dell to good to pass up anyway when i set it up for the kids it worked for 3 months and then when i would start it up i would get a primary driver 1 not found notification which i assume is the hard drive the current hard drive is a maxtor diamond max 9 hddi have researched and i dont if its a sata, pata or serial
  • 413 Answers
First things first .....check for power cable and data cable and make sure they are not tampered or damaged now move to next step>>>
kindly remove all jumpers in HDD now go to
Control panel>Administrative tool>Computer management>Disk management
you can see the disk here and change settings accordingly like assigning path and drive letter if this does not work
then just see that is it recognized in device manager as unrecognized device then update driver for HDD even now if the problem persists
KIndly consult the manufacturer
Thanks And Regards
Posted on May 13, 2009
    Champion:
  • 381 Answers
Hi..try to replace the IDE/SATA cord connector then try again..Thanks...
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
No operating system found
check the bios setup for hdd detection if hdd detected in bios then reinstall or repair your OS
if hdd not detected by bios setup then you have to open hdd cover
you will find a fpc cable betwen hdd & mother board
just open the connector carefully & refit & apply a small tape pice on the connector lock after reinsert the cable
Feb 19, 2011 | Samsung X05 Notebook
Dear sir i have ir3300 cannon yesterday i switch on the machine monitor showing E602-019 HOW TO SOLVE THE PROBLEM
E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0003 A sector fault is detected on the HDD.
0004 A fault is detected in the read /write address for the HDD.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
main controller PCB is faulty.
BUT FIRST: TURN OFF THE COPIER SIMOULTANIOUSLY PRESS 1 AND 9, HOLD IT, AND TURN ON THE COPIER. THIS WILL INITIALIZE THE HDD DEFRAG MODE.
TRY IT, IF NOT REPLACE HDD, AND UPGRADE SOFTWARE - NOTE: FOR UPGRADE YOU NEED THE SERVICE SUPPORT TOOL - CALL SERVICE FOR THATH
Feb 13, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
I have 20 GB HDD which can'not detected is any software detect it
try to check it on CMOS setup, and see if ur HDD is detected there, then also check the jumper settings of your HDD, is it connected as master drive, or slave, then check other devices jumper settings for CDROM or other HDD connected to your PC. (do this for initial troubleshooting)
Dec 14, 2008 | Symantec Computers & Internet
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
860 people viewed this question
David Payne
David Payne
