Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
B&S engine backfires, runs better with choke 1/2 out under load??
22 hp intek b&s Changed fuel filter, spark plugs(gapped at .040 per owners manual), air filter, etc. Back fires through muffler, at all speeds. Engage blades, same thing. Pull choke 1/2 out, and it runs a lot better, with little to no backfiring. Will not run better with choke out when they are disengaged, only when engine is "loaded" Checked fuel filter and noticed it was empty. Presumed I had a faulty fuel pump. "Borrowed" fuel pump from co-worker. Same results. Fuel filter fills up when sitting and mower off. Start mower, and it runs well for 10-15 seconds, then filter get sucked empty and backfiring starts. Is there a screen/filter in tank that is dirty??? Have been told everything from blown head gasket to bad/misadjusted valves to carb plugged. Still doesn't explain the empty fuel filter which I feel is the main problem. I have changed fuel filters since this started with no help. Have never noticed fuel filter to be empty before, always approx 2/3 to 3/4 full when running, but cannot be sure because I've never really paid that much attention when it ran good. Any help would be appreciated.
Andrew
  • Anonymous May 23, 2009
    I had the nearlly the same problem. come to find out it had a bent push rod that had fallen off. I put a new one on and it runs fair. Just seems to be a junk motor
  • aps95z28 Jun 01, 2009
    Ok, mowed 2 weeks ago, and problem somehow disappeared. Mower ran great, started mowing with the choke 1/2 out like I explained above, and hoped off to move kids toy about 20 minutes into yard and noticed no backfiring at low rpm with blades off. Opened the throttle up, ran great. Stayed this way the rest of the day. Got on this last Saturday, expecting the same thing. Nope, started backfiring about 15 minutes into mowing. Only thing I did this week was put new gas in (premium because I was told that 87 octane makes them run like ****, been using it for about a year) and topped off the oil because it was just a tad bit low. I'm pulling my hair out now. Guess its off to the shop with it.
    Andrew
  • 3 Answers
Check your rockers inside valve covers. They some time work loose. If they are loose the push rod will fall off rocker and cause the problem.
Posted on May 31, 2009
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Choke needs to stay on and engine backfires when
COULD BE A CARBARATOR PROBLEM
YOUR PROBLEM IS CALLED ENGINE RUN ON OR DIESELING THIS HAPPENS WHEN YOU TURN OFF THE KEY AND FUEL IS STILL BEING PUMPED INTO THE CARB. COULD BE DIRT UNDER THE NEEDLE VALVE FOR THE FLOAT
Aug 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
2,780 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
