Question about Samsung SH-S182D DVD RW Dual Layer Burner
Not workin on vista
Hi my samsung s182d dvd drive has suddenly dissappeared frm my computer an has stayed in  device manage but in device manager it is saying that the driver is either  corrupt or missing   can you help me solve this problem
    Problem Solver:
  • 14 Answers
Pearson, Im Sure You Installed a Burning Program(Nero)
This Usually Happens Because of Burner Programs
Just Click On The Win ORB Or Commonly Known as Start
Then Run-
regedit.exe If You are Unable To Read Whats Down Go to support.microsoft.com/kb/929461 Its All There
1. Click StartStart button, type regedit in the Start Search box, and then click regedit in the Programs list.
User Account Control permission If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Note After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
Posted on Jan 08, 2008
I'm currently using Windows XP, and have: TSSCorp SH-S182D and SH-S183L. Neither are currently working - they show up in the Device Manager, but the Samsung drivers I try to update them with never...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
Computer does not recognize cd/dvd combo TSST Corp SH-S182D have yellow mark by device in Device Manager appears the driver was lost
Your device may be damaged, but here are some things you can try.
Go to the Device manager and right click your CD/DVD drive and select remove / delete. Now download this VB script and run it. (You may have to right click it once downloaded and select run as administrator if using Vista /Win 7) Restore CD/DVD in Explorer
Now reboot your PC.
If that doesn't work you may also try unplugging the device physically and replug it in, using another SATA/IDE/USB port.
Regards, Chris
Aug 12, 2011 | Computers & Internet
Where do i look for details of the installed drives for my cd-rw and my dvd/cd-rw. its just a hands on question in my computer repair I class
goto control panel, open device manager... you can find all the drivers that are installed in your computer including cd/dvd drivers....
start > control panel > device manager (for vista & win7)
start > control panel > system > hardware > device manager (for xp)
or
right click on my computer icon, select manage > select device manager
Oct 05, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
My computer has suddenly stopped detecting the Samsung CD-RW/DVD-ROM Combo Drive. It does not display E: drive in the Windows explorer. I am not able to play any kind of discs.
Right–click My Computer, click Manage, and then click Device Manager. make sure there are no yellow or red boxes in the left. if it is rede or yellow, right click and update drivers. If this doesn't work, turn your computer off then unplug. Open the case and re-seat the cables. Plug system in, and turn on. If you can't see the drive still under my computer you will need a new drive.
Feb 03, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
TSSTcorp CD/DVDW SH-S182D....its not function.it cant read any cd or dvd.wht should i do?it seems like something missing,maybe the software/hardware.
It is too late to find out the issue and return SH-S182D drive.
SH-S182D drive has compatibility issue, none of firmware (including the latest) is "perfect" so far.
I couldn't do anything but wait for Samsung to release new firmware to fix their drive.
Same **** with my Samsung SH-S182M. In a nutshell, it burns DVD's then can't read them while my old, cheap DVD reader can. Once in a while it manages to read one making me think I've fixed the problem.
All i can say to you is buy a new one my friend.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 17, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
DVD ROM not working properly
right click on my computer --> manage --> disk management and check to see if it has a drive letter assigned ( you should be able to right click on it and assign a drive letter if it does not have one.
If not then look at my tip here
http://www.fixya.com/support/r2099529-cd_dvd_missing_video_codec_video
Apr 30, 2009 | Computers & Internet
Hp pavillion laptop dv6000
I beleive that the DVD Drive icon had dissappeared from My Computer.
However, I recommend you to check in the Device Manager by clicking the + mark next to DVD/CD-Rom Drives.
If you find any entry under the DVD/CD-Rom Drives, right click on the entry and select Properties.
In the Properties window that opens, check the status of the drive listed under Device Status.
If you find any error message with Drivers, we need to make some registry changes to reinstall the Drivers for the DVD Drive which should solve the issue.
Since you had not mentioned the Operating System installed in the Notebook depending on which the steps to edit the Registry depends, I am providing the steps for both XP and Vista :
Uninstalling DVD Drive Drivers from Registry in XP :
http://support.microsoft.com/kb/314060
Follow the instructions listed under Advanced Troubleshooting to edit the Registry in XP
Better way is to copy the entire link and paste it in the address bar of a new Interner Explorer window and press enter key.
Uninstalling DVD Drive Drivers from Registry in Vista :
http://support.microsoft.com/kb/929461/en-us
You may either find the Upper or Lower Filters or Both as per the instructions provided in the links above. Delete the Upper and Lower Filters which ever you find from the Registry and restart the computer which should solve the issue.
However, if there is no entry of the DVD Drive even in the Device Manager, you may have to remove and reinsert the Drive manually as it can be an issue with the connectivity of the Drive with the Notebook.
You can find the instructions to remove and reinsert the DVD Drive from the manual of the Notebook which can be found from the link provided below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructiosn to remove and reinsert the DVD Drive in the Notebook starting from page number 110 of 233 in the Manual.
However, if there are no error messages in the DVD Drive properties window in the Device Manager and if the DVD Drive icon is missing from My Computer window, all you need to do is to try changing the Drive Letter of the DVD Drive from the Disk Management window.
Find the instructions to change or assign a Drive Letter to the DVD Drive in XP from the links below :
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=no&dlc=no&cc=no&docname=lpg40244#N545
http://pcsupport.about.com/od/tipstricks/ht/changedriveltr.htm
Find the instructions to change or assign Drive Letter for the DVD Drive in Vista from the link below :
http://www.tech-recipes.com/rx/506/vista_xp_reassign_change_drive_letters/
http://pcsupport.about.com/od/windowsvista/ht/chdrlettervista.htm
I am sure that any of the instructions provided should solve the issue with the DVD Drive in your Notebook.
Oct 22, 2008 | HP Pavilion dv6000z Notebook
Blank DVD Causes PC Reboot
if the pc reboots, then a driver or hardware fault is the cause, try uninstaling the dvd drive in device manager, then restart pc to install it again, or if you are able connect the dvd drive to another ide cable connector incase its a fault from the motherboards ide channel.
Aug 09, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
Samsung SH-S182D DVD RW Dual Layer Burner Logo
66 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
