Question about Samsung SyncMaster 913N 19" LCD Monitor
Error message on Samsung SyncMaster Monitor 19"
i hope someone can help. I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'. Sure it must be something simple but nothing responding and without the screen I can't re-load the driver or anything. Would really appreciate a simple solution.
Thanks
Sharlet
  • 1 more comment
  • Jesus Raves Nov 29, 2007
    I have a problem, when i want to change a resolution or when i restart system this message comes on screen: "Not optimum mode. Recommended mode : 1280 x1024 60Hz". But changing on 1280*1024 doesn't solve the problem, to monitor starts to work i must plug off the power cable and wait a 2-3 minutes to memory chip in monitor reset. So my question is: "Does anyone have a schematic or know how to I bypass the memory chip or to build one button which i will use to reset memory when the problem apear?"
  • Anonymous Dec 17, 2007
    same problem as listed above ,screen resolution. tried everything changing resolution etc . its hard work when you have no screen
  • Anonymous Jan 08, 2009
    same problem with the monitor.
    John from Athens/Greece
Hi There!
I had the same problem some time ago and I have managed to find a very useful website where explains how to fix it!
The solution comes from a Spanish Forum site, originally written in Spanish! Using Google translator you can have the step by step solution in English, although sometimes the translation is not too accurate!
I have managed to get my screen back to life with a total expense of 25p and 15 minutes of my Life!
Just cut and paste this link!
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I hope this helps!
Good Luck!
Frankie
Posted on Jan 29, 2009
Had exactly the same issue as you.i contacted samsung after trying everything that was suggested and they have sent me a replacement monitor within 7 days .i believe that they are aware of an issue with a chip in the monitor and are replacing like for like free of charge as long as you are still within your 3 year warranty.give them a call you have nothing to lose.
Posted on Jan 06, 2008
This a typical hardware issue. Just unplug the power cord for at least 3 minutes and the screen will restart. Know as a rom problem. must change the rom at samsung service.
Posted on Sep 08, 2008
No solution! Got the proper drivers for XP 64. This started happening here when I switched graphic card to a PCIe XpertVision 6600 LE (nVidia chipset). Never had any issues before on AGP. Also, the 913 gets a black out when PC turns to stand by mode (no screen saver). So I`ll have to do the unplug/plug in workaround again. Rather annoying!
Posted on Dec 30, 2007
  • bjorn1 Dec 30, 2007
    The Magictune software has always been quirky. I remember with my old PCI card that when I fiddled with Magictune I would get random black outs when changing settings.
I have the same problem but couldn't resolve it with driver.
Anything else to do?
Posted on Dec 28, 2007
Hi, rightclick on your desk, properties, settings to the most right, and make your go for 1280x1024, the settings you will find in the lower left so move the cursor. I hope this was your problem, best regards Claes
Posted on Oct 24, 2007
You must use the correct Samsung driver as this panel is sensitive to display settings, while running and changing display settings without a proper driver installed will lock up the memory chip.
The driver can be downloaded from http://www.samsung.com in the support section.
Regards
Bill
Posted on Dec 08, 2007
  • 1,006 Answers
GO TO ---> display properties -settings - advanced and monitor must be 60 hz and reinstall the driver
Posted on Oct 15, 2007
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
After 5 years with no problems, my Samsung SyncMaster 915N monitor is blank with the exception of an error message that says something about needing optimum resolution. At first we thought it might be the...
The optimum resolution for this monitor is 1280x1,024 @60Hz.
The resolution setting is done at the PC not at the monitor.
After 5 years, more likely components failure will be the filter caps in the power supply section, that will be the first thing to look for inside. You can see failed SAMSUNG monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung 914v 19" LCD pixels went out
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
19" Samsung SyncMaster washed out display
You either have a backlighting problem or the power supply is getting weak and starting to fail.
If you have another computer...connect it and see if the results are the same...also check your cables, analog and/or digital for any faults.
Good luck...i hope this helps.
Jul 18, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Screen goes black and have to restart
looks like you have a DRY SOLDER or COLD solder , if your handy with tools , you have to open monitor and check the PC BOARD, specially where some transformer is located look around that area for some burnt spot , re solder it , and try it again , should be working properly , hope this helps AJ
May 02, 2008 | Samsung SyncMaster 940BE 19" LCD Monitor
Error message
Kathryn, In the lower left, under the screen there is a row of buttons... One is labled "AUTO" have you tried pressing auto and if so does anything happen?? If not try pressing "MENU" first and then "AUTO"... What we are attempting to do is to get the monitor to accept the current settings so we can get the screen up and then deal with changing the resolution... In a Windows operating system the resolution is changed by going to "START" - "SETTINGS" - "CONTROL PANEL" - "DISPLAY" and in that window click on the "SETTINGS" tab and reset your resolution. This one might take some better communication that emails - because it would be easier to know in real-time how the monitor is reacting as you input various things... You can give me a call at 360-642-4993 or we can set-up a live chat. I'm assuming since you were able to place this post you have a second computer to work from? Bill
Jun 06, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
4,134 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
