Home | Web Cameras | HP webcam dv6000 is not...
Web Cameras
Problem for Web Cameras
Generic problem for all Web Cameras
HP webcam dv6000 is not working properly
By sandy_1982 on Oct 14, 2007
hi,
in-built webcam is not working properly .
I installed the latest updates available for  the same but in vain.
thnks,
sandeep
Clarification Request
Posted by leboi1081 on Dec 07, 2008
my hp dv6000 webcam is not working and I dont know what to do. please help. thx
Same Problem
Jan 21, 2009
-   I HAVE THE SAME PROBLEM EVERY TIME I PUT ON MY WECAM, I GET A MESSAGE SAYING "CAN'T CONNECT TO THIS VIDEO DEVICE(HP WEB CAM) [PLEASE SELECT ANOTHER CAPTURE DEVICE VIA SETTING OR CLOSE ANY APPLICATION THAT MAY BE USING THIS VIDEO AND RESTART YOUCAM"
EVEN AFTER RESTARTING IT STILL GIVES ME THE SAME MESSAGE.
-   kannagh
Jan 16, 2009
-   i have a problem if i will used my webcam in yahoo messenger-   Guest
Nov 16, 2008
-   i have the same problem with my web cam
every time i open the web comes the error
not found in your sistem-   sandra_83pop
Aug 17, 2008
-   my hp built in webcam duznnnnnt werkkkkkk -   Guest
Aug 15, 2008
-   I am also facing same problem in my HP dv6705au laptop, after installation of WinXP SP02..-   rajesh_tiwar
Best Solution
posted on Nov 29, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks. Takes some work to get it done but it's definitely worth a care.
Solution #2
posted on Nov 20, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Dear Sandy,
This is Soren,from the HP Pavilion Notebooks Chat Support Team, following up on our recent chat session.
I understand that the web cam is not working your notebook. Here are the steps to resolve this issue.
Step 1:Here are two procedures to know about How to use the Webcam in Vista Notebook.
Using HP webcam in Quickplay software:
1. Click on Start button, select All programs and click on Quickplay.
2. Within the Quickplay application, click the Video icon (Icon resembles, camera, music, and film).
3. Double click on "HP Web cam" or “USB Video device” in the Source column.
4. Now you could see your self on the screen.
Using HP webcam on Muvee Autoprocucer software:
1. Click on start, Select all programs and click on Muvee Autoproducer.
2. It will open Muvee Auto Producer. (Click on Trial version if it prompts.)
3. Click on Tools the top and select the Get Video from Camcorder.
4. You would see your self on the screen.
If the webcam does not show the picture you need to perform the below steps. If the webcam works, you need not to perform the below steps. Please ignore the below steps. However, I personally recommend you to save this email and if any time the webcam does not work or if it shows blank screen please perform the below steps.
Before we trouble shoot this issue let me explain the reason for this issue, HP has released new driver for webcam and the driver update process can’t be done automatically and as long as the old driver exists the webcam does not work, To resolve this issue First we need to uninstall the existing webcam from device manager. Then restart the notebook and install the latest driver to resolve this issue
Step 2: Steps to Uninstall the Webcam drivers from the device manager.
1. Click on start and click on Control panel.
2. Click on "the Classic View" on the top left side of the control panel.
3. Double click on the "Device Manager" icon in the list.
4. Click on + next to the Imaging devices. Now you would see one HP Pavilion webcam or more then one web cam listings under the Imaging devices.
4. Right click on each HP Pavilion web cam and click on uninstall. And confirm un installation if it prompts. (Click on Yes.)
5. Now the Imaging devices option should not appear on the device manager.
Note: If the HP pavilion webcam is not listed or Imaging device is not listed, in device manager you need to reset the Bios to enable the webcam. Once you reset the Bios the webcam will listed in device manager. Here are the steps to reset the Bios.
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes"
Step 3: Restart the notebook.
Step 4: Click on the below link and then click on Save button of the download window. Click on brows and then click on desktop then click on Save.
*we need to download the file to the desktop.
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
Step 5: Installing downloaded web cam driver (sp34746).
1. Double click on the downloaded file (sp34746) and follow the on screen instructions to install the file.
Step 6: Once the installation prompts you that the installation has been successfully completed. Now you need to restart the notebook.
Now check the webcam input in Quickplay software using the steps provided on the step no. 1. The webcam should work, if the webcam does not work please verify the below steps.
Step 7: Enable the Imaging services on the notebook.
1. Tap Window key(flag key on the keyboard) and R key on the keyboard, at once.
2. You would see the Run window on the screen.
3. Type SERVICES.MSC and hit enter.
4. You would see the services window on the screen.
5. Double click the "Windows Image Acquisition (WIA)" service, and under the startup type select Automatic.
6. Click on "Start" button if it is stopped under Service status
7. Click on Apply and Ok.
Step 8: Now check the webcam in quickplay or Muvee software. verify the step 1 to know about how to use the webcam in quickplay or muvee.
If the still issue persists, Please check webcam name in device manager. If you see USB 2 Video device under the Imaging devices the webcam works properly (it means latest drivers have been loaded successfully). If you see the HP Pavilion webcam under the imaging devices, it means still the notebook is using old webcam drivers and you need to repeat the steps from Step 2:
Note: Please do not reply to this email.
I wanted to be sure that the troubleshooting steps suggested by me was useful and helped you in resolving the issue. If the issue persists, please contact us by visiting the following Web site:
http://welcome.hp.com/country/us/en/contact/chat_1.html
Thank you for using HP Total Care and giving us an opportunity to serve you through chat support. Please contact us again if
you require any further assistance. We are available 24 hours a day, 7 days a week.
Regards,
Srinivas Mannapuram
HP Total Care
Solution #3
posted on Sep 17, 2008
Helpful)
zionyahweh
Rank: Apprentice
Rating: 94%, 4 votes
Weird but worked for me for yahoo and messenger but not quickplay. If you have the Chicony web camera, follow these steps to download Acer webcam drivers.
1. Download Acer 5210 Chicony Webcam drivers.
2. Run the setup file.
3. Follow installer prompts then RESTART PC.
4. Ignore the 'installing drivers' popup.
5. Open up the Control Panel.
6. Open up the Device Manager.
7. Select webcam from 'Imaging Devices'.
8. Right click on webcam and select 'Update'.
9. Select 'Browse computer for driver'.
10. Choose 'Let me pick from list of devices on PC'.
11. Uncheck 'Show compatible hardware' checkbox.
12. Scroll down to Chicony manufacturer.
13. Choose the 'Acer Crystal Eye Webcam'.
14. Install even if a question pops up.
YOU ARE DONE AND ENJOY YOUR CHATTING WITH ACER CYRSTAL EYE WEBCAM.
Thanks to DylanBennett for uncovering this odd fix for the HP webcam
Comments:
Sep 17, 2008
- Hi guyz,
If the above solution worked then you can capture photos and videos and using your webcam by simply installing a free programme called Debut you can download on this page:
http://www.nchsoftware.com/capture/
Enjoy and good luck with your HP webcam chatting.
ZionYahweh
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
Answer
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any... (More)
Answer
lost disk for Micro Inovations Basic web cam IC50C need drivers to download
Answer
I have an Ezonics IV webcam but the mic doesn't work
11 Other Users Have The Same Problem - Continued
Comment by shanor_1984, posted on Aug 09, 2008
cannot connect to device
Comment by texx05, posted on Aug 07, 2008
when i turn my computer off the webcam goes offline and refuses to work
i have to download the same program over and over and then restart my computer fo it to work and evebn then its a **** shoot
Comment by Guest, posted on Aug 05, 2008
very blurry and slow and there is no sound
Comment by Ad the Bad, posted on May 02, 2008
I have a HP Paviliion 6580ee laptop. The video icon does not appear after I open Quickplay. I cannot therefore start my built in webcam using /Quickplay. I downloded Quickplay from hp.com but the problem is still not resolved.
Comment by misu, posted on Jan 27, 2008
my hp pavilion dv6560ee web cam is not working i can open the web cam with quick play but when h'm trying to set up my web cam in the msn messenger it is not working it is giving me a message the msn explorer has stopped
Comment by Guest, posted on Nov 30, 2007
same problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Web Cameras:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14774
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
