Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Cabel clutch where cable clutch sprin attaches to mower deck
  • 376 Answers
I think you're asking where the clutch cable attaches to the deck. It slips over the top of the mounting bolt on the idler pulley with a cotter pin through the hole on the top to keep it in place. It is the pulley that swivels to tighten the belt. Hope that helps..........
Posted on May 15, 2009
I NEED THE LOCATION TO ATTACH THE PTO CLUTCH SPRING.
need to know what mower exactly
Jul 29, 2015 | Garden
Clutch cable routing for a craftsman 971289010 lawnmower
The PTO cable will come out the chassis straight down from the engagement lever on the right side of the dash panel. Will be fastened to the frame on the right side in front of the rear wheel with a zip tie. Loop over the brake rod and attach to the deck on a tab at the rear center of the deck. A hair pin will secure it there. The inner cable continues from there under the belt and the spring hooks into the engagement bracket. There may be two hole for the spring to hook into. They are marked 38 or 42.
Sep 02, 2014 | Craftsman Garden
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i re-attach the mower deck? everything is back together but the sprin on the cable. where does this go?
it goes on the the pulley on the deack youwill see the one with long bolt it goes on that bolt the bolt has hole in were a pine gose
Sep 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Broken manual clutch cable
You can go to www.Searspartsdirect.com and put you units model number in and order the cable yourself. They can ship it right to your house and you can swap the cable yourself with just simple hand tools.
You can see the details on the idler attachment in the parts schematic when you are ordering your new cable.
Good luck and be careful!
Jul 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
375 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
