Television is ON only in Standby Mode.Power supply is not switched ON by remote or by manual.
    President:
  • 1,348 Answers
Unplug the set and plug back in after 2 minutes.
if it does not boot up manually there is a problem in the set.
Posted on May 13, 2009
  • kirtec auto May 16, 2009
    thanks for the low rating.just so you know,i have repaired 100 sets with a problem like that,and alot of the time it is a thermal problem.
    if you unplug the set,the 5 volt power supply which controls the relay to turn on the set can change it's operation.
    if the set boots and shuts down,the main b+ 160 volt circuit could be not regulating to 127 volts and the flyback circuit will shut down because the 28kv is exceeded and the xray protection circuit kicks in.if you hook up a variac and set it for 100 vac and the set comes on,that is the issue.check and see if there is a jammed button on the tv,it will freeze the microprocessor from getting data to turn on the set.there are hundreds of possibilities,so start with the obvious.
    does the relay click inside to turn it on?if there is a click,then the hot side of the relay is burnt.
    just so you know,i have repaired over 5000 televisions.
    a make and model is a help,and unless you know what you are doing,a tv is an extreme shock hazard.it can kill you.
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
Mar 03, 2015 | Televison & Video
Hitachi LCD Television
it appears that your power supply module is malfunctioning this seems to be a common problem. you need to replace it have a local tech replace it for you
Sep 01, 2008 | Televison & Video
Stereo amplifier remains in standby mode
You should be able to find a Universal remote that will cancel the standby function.
Mar 31, 2013 | Audio Players & Recorders
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
Nov 12, 2009 | Polaroid FLM-2601 Television
Philips TV 29pt3425 after a while switches off to standby mode but no red standby light is on. It can be switch on using remote by switches off again in a 2 seconds
Ur power supply board,have burn capacitors,check for puff up caps,know how to solder?If not,no puff up caps,change the whole power supply board it somethings burning not notice, able to see in the power supply board.
Oct 26, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Only standby red light comes on. power button or
There is a failure on one of the circuit boards, and or the power supply itself. The main uPC, or the power supply controller is putting the main power supply in to protect mode.
You would have to send the set for factory service to resolve this issue.
Jerry G.
Oct 10, 2009 | iLO 3200 32 in. LCD Television
When switch on power LED comes on and goes off in about 7 seconds and then the STATUS LED comes on. Please tell me what I can try.
if you have the habit of leaving your device in standby mode (switching off in remote only and switching off the power supply), you have to consult a service perssonnel and get your circuit chip dealing with the power supply inside your device. it might have busted up if you have the practice that i specified. please do not leave your device in stand by mode for a long time..
May 27, 2009 | Hitachi 50UX57B 50" Rear Projection...
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
Mar 06, 2008 | Fujitsu Plasmavision P42VCA30EH 42 in....
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
