Need a High - Low Switch for a Rival Titan Heater Serial # 404 Control # 761 404 . Please let me know Albert [email protected]
Albert, I have serious doubts that you'll find a suitable switch for your needs on this type of a unit. They just aren't available, unless you can walk into a hardware store and know just what you want. Otherwise, these things are made in China for the most part, and when they ship them over here, they don't ship replacement parts for them...
SOURCE: Need switch fort Presto Quartz Heater
Hello
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
SOURCE: heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: HF 8 Space heater with a bad switch
If you locate and procure a switch, you can more than likely replace it yourself. Get a switch of like and you can see what you have to deal with, Always disconnect the electricity before you work on it Good Luck. It really isn't a big deal to do.If you can take and send pics by e-mail I can walk you through. [email protected]
SOURCE: Where can I purchase a new Rival space heater,
I have two new ones without boxes, if ouy'd like to but one.
