Question about Canon CanoScan LiDE 25 Flatbed Scanner
Clicking noise scanner stuck
Scanner arm only moves VERY short distance and then starts shuddering and clicking and won't continue to scan.
  • 477 Answers
Have you checked the scanner lock ? it should be off.
Posted on May 13, 2009
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Scanner won't scan. the light is on but the scanner part won't move. makes a lot of noise. the belt is not brokern
depending on the scanner the belt may not be broken, however the gear that it rides on may not be moving, or the belt is slipping. Some scanners the glass can be removed for you to visially see the gear and evaluate from there
Jul 15, 2011 | Office Equipment & Supplies
My Epson scanner makes whirring noise
There are a couple possibilities that can cause the problem.
1. you need to unlock the scanner. There is a lock at the side of the scanner that could be in the locked position which is preventing the scanner from moving. you can use a nickel or penny or screwdriver to turn it to release it.
2. the tab that is holding the gear is broken
3. the glass is not attached 100% to the upper case and the scanner is hitting it when trying to scan.
if its 2 or 3, you might be better off getting a replacement.
thank you
May 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
Jan 05, 2010 | Epson Perfection 2400 Photo Flatbed...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Canoscan 4200f clicking noise when turned on
Cool. I bought the scanner 2-3 years ago and i had the same problem. I gave it back, received a new one ... exactly the same noise ... on 3 different computers. **** product!
Jul 30, 2008 | Canon CanoScan 4200F Flatbed Scanner
Scanner not working after being stored for a year
You must always 'lock' the scanner before you move! It is very sensitive. If you are scanning at 300 dpi, the scanner motors moves the platten by 1/300th of an inch and then the data is scanned. This is a continuous process, but you see only the platten moving.
There are are small plastic 'catches' on the back side. The top portion is 'press-fit'. Carefully remove every plastic catch and you can reach the inner parts. Most probabbly, the clacking noise is because the motor is not able to drive the platten. If you can reset it properly, then the scanner is ready! Ensure cables are not disturbed.
S. Mohan
Jul 27, 2008 | Canon CanoScan D1250U2F Flatbed Scanner
Umax Astra 1200S Scanner Problem
Open ur scanner ,s back body(its very easy)remove belt.. just clean scanner, s belt and dust from scanner with soft cloth..put it belt again..
Mir
Jul 05, 2008 | Umax Astra 1200S Flatbed Scanner
HP Officejet 6110 scanner carridge appears stuck
Unplug the power. Plug back in, while simultaneously holding hash (#) and (6) buttons, until S-reset is displayed (sometimes this can take like forever) but it is a documented HP mode.... Then set up machine using 1 key to confirm options and arrow keys to select options.
To enter another maintenance mode (fat lot of good that will do you), press and hold * and #, then press 1 and then 2 and then 3 (or 5) for a variety of different options, which include testing of the scan bed. This of course only works once the scan bed has initialised...
Or: take out all cartridges and close doors. Wait until it complains, or indicates a cartridge jam.
Regards
All-knowing.
Oct 20, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon CanoScan LiDE 25 Flatbed Scanner Logo
618 people viewed this question
old marine
old marine
