Question about Dryers
The dryer is running but sometimes hot and sometimes cool when it should be hot.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 68 Answers
Hi friend , wt u can do is contact the retailer or the dealer. It basically has a trouble in disfunctioning which is otherwise also known as loose connection. U need to get it checked by the technician and if your dryer falls under warranty period u may even get the servivicing done for free or if lucky enough u may also get it replaced. Have a Great Day!!!!!!!
Posted on May 13, 2009
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Dryers
Dryer heats too hot instantly. Ok on cool down or blower only cycle. All vents are clean.
heatman101;
Aug 06, 2011 | Hotpoint Dryers
My dryer runs for about 10-20 minutes then shuts off because it must be overheating. After it cools down I can run it again. Is that an element problem?
heatman101
Aug 01, 2011 | Kenmore Dryers
Model # dbxr463eg1ww, dryer overheats and stops sometimes, only on reg heat, after cools off starts right back up. Sometimes it goes thru cycle and sometimes it stops again. Top of dryer gets very hot to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | GE Dryers
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
I have a ge gas dryer. Sometimes it will get hot sometimes it stays cool.
either the ignitor is getting a break in it or the flame sensor "eye" is dirty or the control board is defective
Aug 30, 2009 | Dryers
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
