Question about Tally T8024 Laser Printer
Registration jam Tally T8024
When ever i turn on my printer it says registration Jam open cover A
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
PLEASE UNINSTALL THE PRINTER DRIVER AND REINSTALL IT AGAIN..........THAT SHOULD HELP..
Posted on May 13, 2009
Se me presenta un error en mi impresora Tally T8024 este esta cifrado 06-370 en la pantalla de impresora alguien me puede ayudar con esto......??
Posted on Jan 31, 2010
Where can I get a driver for my new Mac for Tally 8024 colour laser
Click the link below and it will show you where you can download the driver for Tally 8024.
http://drivers.brothersoft.com/tally-t8024-printer-pcl-driver-ver-01.02-22736.html
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Tally T8024 Laser Printer
Windows 7 driver
Try this: http://www.bravofiles.com/download/Tally-T8024-PCL6-cjG3EhpGa5.html
Feb 26, 2011 | Tally T8024 Laser Printer
I CLEARED A PAPER JAM ON T8024 AND RESTARTED THE MACHINE. IT STARTED SHOWING REGISTRATION JAM. HELP ME TO SOLVE THSI PROBLEM
Hi
Check the following possibilities that may causing the error message.
1. Some times more paper may be taken in the paper feed area, check for any other paper jam in other area of the printer.
2. Remove all the printer drives, ports and uninstall the printer software and once again reinstall it by following steps given below
Start - Control Panel - Add and Remove Programs - Remove the program in the list called Tally Laser printer.
By now you have uninstall the software and now reinstall the software with the available cd given at the time of printer purchase and start printing.
Thank you
May 11, 2010 | Tally T8024 Laser Printer
I need a replacement paper tray for our Tally T8024 which has now broken. Thank you Jacky
Tally T8024 Paper Tray
Part Number 050K50140
Description TRAY ASSY LOW TAL
Call Toll Free
1.800.544.5345
(Please give be a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | Tally T8024 Laser Printer
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
Hi when should I think about replacing my T8024? It is 3 years old and has done 126242 sheets.I also have to fix jams at least 3 times a day. thanks brian
You may want to order a Maintenance Kit, which replaces the rollers, transfer roller and fuser, which will basically set your printer back to 0 pages and stop frequent jams also. No need to spend all that money on a new one.
Nov 05, 2009 | Tally T8024 Laser Printer
Hp printer says theres a paper jam- but paper is no longer jammed
if you open and close the toner cover,do the motors turn at all?if not then the printer thinks there is a jam and so one of the sensors may be blocked or stuck out of position.ususlly this would be one of the main path sensors like the delivery exit sensor at the fuser in the back.in which case you can pop off the back rear exit cover and you should be able to see it or you can pop upwards the 2 clips inside there and take out the fuser if you need.
the other sensor would be the "top of page" sensor in the registration area.take out the cartridge and lift the registration flap directly under it and look down in there.
Aug 07, 2009 | Office Equipment & Supplies
Tally t8024 error message "set drum cartridge"
The 'Set Drum" error indicated the printer is not detecting the drum cartridge as being located in the printer.
I would recommend doing the follwoing;
  1. Ensure the drum cartridge locates correctly in the printer. Remove it and re-seat if necessary.
  2. Ensure the top cover (the one that opens upwards to change the drum) shuts correctly, this cover pushes the drum into the printer.
If the above actions do not fix the problem, I am afraid the covers will need to come of the printer. There is a gear mechanism located on the left side of the printer that operates when the top cover closes.
This gear mechanism will need to be aligned with the alignment marks, it sounds like the gears will have slipped and the timing is slightly out.
Mar 09, 2009 | Tally T8024 Laser Printer
Flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
 If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
 If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
Jun 07, 2008 | HP Color LaserJet 2550n printer + HP Color...
Tally 8024 Registration Jam
if you have the original disc the printer came with, uninstall and reinstall the driver's, that should clear it up.. if you don't have the disc, go to the website and download them from there.. let me know if this helps.. what type of printer is it? manufacturer? thanks, d
Feb 26, 2008 | Office Equipment & Supplies
Tally T8024 Laser Printer Logo
190 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
