Question about Hitachi 43FDX15B 43" Rear Projection Television
Double IMAGE of RED
I have this 43fdx15b. It is getting a double image. Whats actualy doubling is the red. Im not sure what i should do at this point i want to repair it myself but i want to know where and what it can be.. who ever can help me thankss
  • 2 more comments
  • Superstar619 Feb 21, 2008
    I have a double image of red on the left side of the screen and its hard to see the picture. I've tried fixing the colors but it doesn't seem to work? What can i do?
  • Anonymous Apr 27, 2008
    I am having the same problem double image of the red. They want 130.00 just for a service call and said it could be up to 500.00! I think I might as well buy a new tv for that price!
  • anita_mar10 Jul 30, 2008
    I have double images on left side of screen. They look hot pink and green. Now the right side is having the same problem. I tried to use magic focus, but it stops on the green at 5
  • Anonymous Jan 03, 2009
    this tv is junk the 43fdx15b I think I will fill out a report and give it to the better business had tv fix two years ago now doing same thing
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 1,694 Answers
Replace STK-392-110 IC's mounted on large heat sink.Check
B+ resistors with meter or at least look at them = any heat stress?
Let us know if you need more help....T
Posted on Oct 26, 2007
    Problem Solver:
  • 11 Answers
Your tv has a convergence problem there is a small chance that you might have bad solder connection on the convergence ic's but most likely the ic's are bad and if they are you should check the resistors in the convergence
Posted on Oct 16, 2007
My jvc has picture but it is double and reversed
Double Image JVC - AVS Forum ' Home Theater Discussions And Reviews
Jun 4, 2005 - 30 posts - ‎11 authors
Have a JVC 52 , only a few months old. ... That looks like my CRT RPTV if I mess with the convergence. ..... I hope your repair isn't that drastic, but you won't know until after the service tech gets there. .... Started out with a double image, then mirror image, then finally the blue and red went out totally leaving ...
Jan 01, 2016 | JVC Televison & Video
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
Hitachi 43FDX15B 43 in
You can try replacing the convergence IC's ...should cost you about 350-400$..Its your choice at the end of the day,,It could also be that the lamp is blown and you will need it to be replaced. Best a tech and get a quote and then decide..
Jul 19, 2008 | Hitachi 43FDX15B 43" Rear Projection...
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
Jul 11, 2008 | Akai PTH5498 54" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
