Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer
Dryer will not heat.  All cycles are air dry only.
  • Anonymous Mar 12, 2014
    The upper drying cabinet of our Maytag Neptune MCG8000AW Gas Dryer turns on but is not producing any heat. It has power and light but no heat to dry the shirts when I put them through the cycle.
How do you open the outer shell of a Maytag Gas dryer to change either the igniter or thermal fuse???
Posted on Feb 15, 2009
  • 291 Answers
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 14, 2007
4 Suggested Answers
  • 67 Answers
SOURCE: Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Posted on Oct 28, 2008
  • 300 Answers
SOURCE: Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Posted on Mar 07, 2009
SOURCE: The gas maytag neptune intellidry gas dryer does
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Posted on Jul 11, 2010
Dryer gets hot, outside vent seems to have plenty of air coming out. Lint screens all clean. But the unit takes two cycles to dry and in the past it always dried in one cycle. Whats wrong??
Is this happening on automatic dry cycle or timed drying?
It sounds like your moisture sensor is "confused" and shutting down heat prematurely.This part can be replaced.
Also double check your exhaust vent for blockages or standing water or sagging or open pipe
Also , your heater element may be shutting on or off prematurely. Could be a high limit thermostat problem. Or there is obstuction causing over heat
hope this helps
Aug 15, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune gas dryer-gets warm and then air goes cool
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
155 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
