Question about Philips Televison & Video
Tv switches off by itself
Philips 29pt6021 tv switches off by itself after a time. I heated up the small signal panel and now display wont show channel numbers
    Problem Solver:
I saw a no of similar problems on your site. Seems to be the painter chip/small signals board
Posted on May 13, 2009
Why does it take so long for the channels to change? Screen goes black as they change
The TV tuner takes time to decode the cable signals. There are several resolutions (720,1080p, 1080i) and screen display ratios(4:3,16:9...).
In my TV setup you can let the TV decide which is the best display ratio or you can choose one and it will adapt each show to that. The preset one changes channels faster.
I also switched to a high speed HDMI cable with very good results.
For more info see:
slow to change channels
May 11, 2016 | Televison & Video
I have a very elderly Philips CRT type TV previously owned by my late father. We use it for our grnadchildren to watch VHS tapes when they visit us as the live TV facility went with the switchover to...
hi if the tv has a scart socket plug scart lead from tv to settop box and it should work fine
crt model numbers are usually right at the back of tv at the bottom under the big bump on back sometimes on the side sometimes even underneath hope this helps need more info please email me
Jun 23, 2011 | Philips Televison & Video
Philip 29PT6021 switched off suddenly
Capacitors problem in vertical circuit
Sep 12, 2009 | Sony KV-32FV1 32" TV
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
the tv may be overheating
try putting a small fan blowing air directly behind it.
if this doesnt help then you may need to take it to a repair shop.
Apr 26, 2009 | Televison & Video
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv wont remember channels...
replace your " small signal board " ssb to a tv tech.
that will solve your memory problems
Jan 21, 2009 | Philips 32PF7320A 32 in. LCD Television
Audio switching rapidly between mono & stereo
it's almost like an antenna so if he lives in apartment or anywhere lots of signals are it will do that i would suggest a line clarifier
Aug 22, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a plasma TV MAGNAVOX PHILIPS model-42MF7010/17
video processing is done on small signal board. If there is no on screen display ssb would the board to replace as micro processor generates the menu
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sharp Aquos TV
The tv wont turn on ... the gren power display keeps blinking and won't turn on...
What can I do? Thank-You! KarL
Feb 24, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Televison & Video Logo
120 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
