Question about Averatec 3150H Ultra Thin Notebook PC With Athlon XP-M 1600+ (3150HSDG) PC Notebook
Does the hard drive interchange with other Averatecs?
I have more than one Averatec (but different series), and was wondering if the hard drives interchange. I have a problem booting up one of my older ones (3150) and was interested in simply swapping hard drives with my other one (3280) that does power up, and back up my data. Thank you for any help in this matter. God bless ><>
  • Averatec Master
  • 32,281 Answers
Swapping hard drives only works if the hard drive is swapped into an identical computer with the same device configurations, CPU and RAM etc.
The best way to copy or recover data from a working hard drive is to insert the hard drive into an USB hard drive adapter and plug it into a working computer's USB port. You should see this drive as an external hard drive and you can then copy or backup the data onto the computers hard drive or USB memory stick etc.
Posted on May 13, 2009
I have been given a Averatec series 3200 laptop along with 3 different hard drives ,can you tell me which Seagate and Hatachi hard drives fit this computer
what are the HDDs you have... type and size and speed is needed.
and if you can plug in one. then see if it boots, and works. then that one is proper, and you can test ea HDD and mark it will accept :
20gb, 30gb, 40gb, 60gb 80gb, 120gb,250gb - ATA 2,3,4,5 interface
Mar 03, 2015 | Averatec 3200 Series Notebook
My averatec laptop is locked how do I get in?
If it is user locked a hard restart (power down power on) will unlock it.
if it is password protected and you have "forgotton" the password reinstall it from OEM (factory) disks/cd's.
if you MUST access the data on the drive, remove the drive and use it as a secondary drive or a usb drive (with a usb to HDD cable) and take onership of the files that way and move them to a new media, then reinstall your pc.
If your not comfortable with that seek a repair shop.
Aug 17, 2009 | Averatec 3200 Series Notebook
Averatec serie 3200 crashed new hard drive need drivers
the same way you typed it here try google it gives you the drivers then you install.
Jul 04, 2009 | Averatec 3200 Notebook
Disk read error
A disk read error on boot is an indication that the hard disk drive is failing and needs to be replaced.
If the system is under warranty, then contact the manufacturer/warranty provider. If not under warranty then you have to replace or have the hard drive replaced for you by a technician.
Portable hard drives are fairly inexpensive ($100 or less normally) and labor to replace one should run $50 to $100 or so.
Jul 23, 2008 | Averatec 3200 Notebook
Averatec 3700 series
Quote from mewms_14904 on May 28, 2008
"The hard drive is located under the plastics on the right below keyboard. Accessing is a pain and a bit of trial and error."
Jul 11, 2008 | Computers & Internet
Averatec 2300
My 2300 started same problems in Dec 08 (almost 2 years old) Its an overheat problem! With black screen the two blue lights an bottom left are on. Leave powered up and in an hour or so will shut down on its on, then will start back up normally but shut down again in about an hour.Correction 1. pull off back cover, blow out the dust. 2.Go to set up (F2 on power up and run fan cal) 3. Take the back cover off you will feel how hot the CPU and hard drive are that is because vents are too small for an aging laptop. Now take the cover and drill a double line of holes on each side of the hard drive vents, Next over the CPU (where the fan blows in air, drill a triple line of new vent holes in the cover). A 5/32 drill will be about right. You may also wish to purchase an inexpensive Belkin laptop cooler. About $19 at Best Buy. This solved my problem as I do like this little one for travel
Glenn New Mexico
Jun 22, 2008 | Computers & Internet
How to replace hard drive in Averatec 3700 series notebook
The link to all the manuals is no longer valid, Averatec has been purchased by Trigem. Averatecforums.com and Averatec-forums.com have both gone under and there is painfully few dis assembly guides available.
The only one I've been able to find that was useful is found here:[url]http://www.larwe.com/technical/av3715-open.html[/url]
Goodluck pulling out your hard drive.
Apr 11, 2008 | Computers & Internet
Wireless connection
The signal may be getting interference, try restarting the router. If this does not work, you may be out of luck.
Oct 29, 2007 | Averatec (70-822301-00TRI) (7082230100TRI)...
Buying a hard drive for the Averatec 3200 Series
I have a tip. Don't forget to set up the drive as master or slave (depending on what you want the drive for). I personally have forgotten to double check this on numerous occasions (its always the simplest thing you overlook with everything) only relizing when I have the case screwed back on and am trying to boot the drive up.
Aug 11, 2007 | Averatec 3200 Notebook
Averatec 3150H Ultra Thin Notebook PC With Athlon XP-M 1600+ (3150HSDG) PC Notebook Logo
114 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
