Question about Palm AT&T C/PHONE PALM CENTRO S64801
Replace the keypad on a palm centro
I ordered a new keypad with the on off and arrow buttons for my palm centro and i cant figure out how to replace it
    Problem Solver:
  • 9 Answers
First off you need a t6 screwdriver. this is a special screwdriver with a star shaped bit specifically used for the screws in your centro. if you don't have one, you can buy one off ebay cheap or maybe even borrow one if you go into your local cell phone shop. they probably could even help you replace it if they're nice, even if you didn't buy the keypad from them.
start by taking out your stylus, your battery, and the little rubber plug thing on the opposite corner from your stylus. it just kinda pops out if you get under it with something pointy like your nail. set these things aside somewhere safe. there are six screws to take out, one under where the stylus was, one under where the rubber bit was (there are three holes here, the middle one is the screw hole), and four more that are super easy to see with the battery cover off. take out all six screws and put them somewhere safe too. then gently pry the back housing up from the bottom and pull it downward with a little wiggle and it will come right off. there is a smaller separate piece that surrounds the hotsync cable port and charger port and this comes out too. set these aside.
the next piece we will take out is the motherboard. you will need to disconnect the screen and the keyboard. they are actually under the motherboard but connect to the top side. lay your phone facing down on the surface in front of you and there will be two pieces of black tape toward the bottom of the exposed motherboard, one on either side. gently pry them up, folding them back toward the edges of the phone but do not remove them completely. this makes it easier to replace them later. under the tape are connectors for the ribbon cables that connect the screen and the keypad. there is a small grey bar that locks the ribbon cable in place. gently pry them up, flipping them toward the center of the phone. then gently pull the end pieces of the cables out of the connectors. they will kind of just point up toward you, not flop back over the edge of the phone.
lift up the motherboard by the bottom, like where the hotsync cable goes. pull the motherboard down toward the bottom of the phone while gently (or it will break off) lifting up the part of the housing that covers the speaker and the camera. set the motherboard aside.
now there is a kind of sticker that looks like gray mesh covering the back of the screen and the keypad. pull this up gently from the bottom wherever you can get an edge started to pull it up. you can stop pulling when you get to the part where it's just covering the back of the screen because you won't need to get under there. the flat ribbon cable that goes to the screen might stick to the mesh, and that's ok, just push the whole thing up out of the way.
now you can lift up your phone and gently push the keyboard back through from the front. it will kind of pop out. it helps if you hold the phone facing down still and use your thumbs to kind of push the sides of the phone out a little so the keypad can just pop back. at this point you should have the part that is the keyboard with the cable sticking out of it, and if this is the part you need to replace, ignore the next paragraph. if it's the actual arrow and power keys, read on.
the green and red buttons (or power and talk) and the 5-way navigation button are all connected together and you can replace this whole piece by just pushing it out from the front, and setting the new one in it's place. it's easy to get mixed up, so just in case, the green button is on the left front and the red button is on the right front.
now there's just putting the phone back together. pop the keypad back in (check the front to make sure it looks right and it's popped in all the way). re-stick the mesh back down over top of it. make sure you have both cables showing and they didn't get stuck under there. take the motherboard and slide it back under the speaker cover (lift it up and wiggle), and make sure the cables don't get caught under it. it takes a fair bit of wiggling to get it sitting in there flat. reattach the cables by sliding the ends into the little slot. if you look carefully, there are little guide lines on the keypad cable that come just to the edge of the connector when it's all the way in. flip the little gray bars down to lock the connectors in place and restick the tape. put the little plastic piece from the bottom back on (it only fits one way) and then put the back housing on and push on it until it kind of clicks into place. replace all the screws, the stylus, the battery and the cover. you're done!
Posted on Jul 03, 2009
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Tried to lock my palm centro never gota question to set password just lock the device now cant get in my phone.
You may want to try a hard reset. Keep in mind you will lose all data in your phone. These steps restore the phone to factory settings
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the Palm2_bing.gif logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Dec 14, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
I can't log out of facebook from my palm centro!! how do log out??
1) Press the options key on the bottom right of your keypad (next to the alt key). A drop down menu will appear on the top of your screen.
2) Scroll over to the options tab.
3) Scroll down to the Settings tab
4) Logout button will appear
Oct 28, 2009 | Palm Treo 500 Centro
Keys on my palm centro won't work!
Some phones have a keypad lock so you dont accidentally hit the buttons if its in your pocket or something. Maybe try to go to settings and see if there is anything like that.
Sep 13, 2009 | Sprint Palm Centro Smartphone
CANT USE ANY BUTTONS ONLY TOUCH SCREEN
it is toast, yes dropping does it, so does camping, (moisture). if you got the insurance then you are ok just go replace it cheap, and pray tht you can get your data on the new one.
Aug 18, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm centro wont boot
Do a reset. You will lose all items on you device.
Take battery out. Put it in and hold the power button on till you see the palm logo the second time. Release when you see the 2nd logo. It will prompt you for pressing up to delete and reset. Press Up. It will take some time to reset and reformat but please wait.
After that your phone should come to the setup screen. I would hotsync after you setup to get your contacts  back.
Apr 25, 2009 | Palm Treo 500 Centro
Its locked up
Is your Palm Centro device locked up and frozen. You might want to try a hard reset. Here’s how.
3. When the second Palm logo appears, release the power button.
Mar 31, 2009 | Palm Treo 500 Centro
Blue tooth for a palm centro
the problem was that you must open the headset after you hold the talk button till the light comes on then flip it open and the light stay on so that the phone can receive the signal.
Jul 09, 2008 | Palm Treo 500 Centro
Hard reset for palm centro
When performing a hard reset on the Palm Centro, you hold down the power button as you insert the battery, and then release the power button when you see the second Palm logo.
http://www.palm.com/us/support/downloads/centroupdate/pop_centrohardreset.html
Jun 29, 2008 | Palm Treo 500 Centro
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
1,399 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
