Question about Refrigerators
Amana Bottom Freezer
When the compressor starts & runs for a few minutes there is a rattling sound that becomes louder for a time & then quietens down (still remaining loud). it sounds like a condenser tube inside the compressor compartment that is rubbing on the frame. The compartment is sealed so I do not know how to insulate the pipe to stop the rattle. I have checked the fan compartment  & the rattle is not from there. If I press firmly on the back of the fridge, the noise level will decrease, but start back as soon as the pressure is released. someone mentioned to me to drill a hole in the back and fill it with expanding foam. However, I do not know how close the condenser tubes are to the back wall, and I do not want to take the chance to pierce one.
  • 248 Answers
  I have found tubing rattling against plastic tray on right side in back.  Also found this tray rattling against frame.  You can take back off unit and llisten for noise.   Watch out for spinning condensor fan blade.  Very sharp,  believe me!!  Try pressing on tubing.
Posted on Oct 15, 2007
Why doesn't my Kenmore Refrigerator/Freezer freeze food?
The compressor could be failing, especially if it was running when the power outage occurred.
Jul 15, 2014 | Kenmore Refrigerators
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Kenmore 65234 bottom refrigerator has a hum/rattle for about 30 seconds then quiet, then after a couple minutes, it does it again. Sometimes for an hour this repeats and sometimes does it for a few cycles...
Might be the compressor relay is fixin to depart this life. themobilian_1937.jpg
If this relay starts sticking all the windings will remain active and overheat the compressor. The overload will tae notice and shut the whole shebang down. Once it cools and makes contact the circus continues until the relay finally disintegrates. The last death throws will be a constant clicking followed by noticeable cooling loss in the ice box.
Amana bottom mount service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 24, 2009 | GE Refrigerators
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Refrigerators Logo
374 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
