What height should the flames on my rangetop be? They seem to be small, barely coming up to the bottom of the burner cap. The unit is older but we just installed it...The regulator had the LP side up and I switched it to NG...I checked all of the the orifices they are all a #50, which seeems to be the correct size based on the parts list online. All of the burners produce the same size flame, so I've been told that it is not the regulator...??? I spoke with my plumber who added the new gas line for the unit and he said there is plenty of gas coming to the unit. According to specs these burners should put out 15000 BTU and they will get hot, but the flame height and speed does not seem to be correct. Any thoughts?
SOURCE: viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
Thanks, but I had already adjusted those screws as per the owner's manual. They fine tune the adjustment at the low/simmer level, but have not effect on the flame height on high. Anyone else have a suggestion?
