Question about Cherokee Jeep Grand - RBB AM/FM Stereo Radio w/Cassette Player and integrated CD Changer Controls
Turn signal fuse
I have a grand Cherokee and the turn signals will not work. I was sold a flasher fuse but I cant find the location for it. Can you help.
  • Terry Drake Oct 14, 2007
    My local dealer just closed down. I need help if you can.
  • Camilo Perez Mar 30, 2008
    • Where can I find the turn signal flasher on a 1992 Buick Regal
I have an acura cl 2.2 and turn signals won't work checked all fuses and still nothing what else can it be.
Posted on Jan 22, 2008
SOURCE:
1999 jeep grand cherokee - rear driver turn signal and brake light don't work. flasher, back up and running light works. everything works when lens assembly is plugged into the passenger side. can...
Check this diagram (click over pic for zoom)...
Check the postion F4 / 15 Amp ( Lt. Blue ) Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094)
Repair tip: WJ flasher repair.
Hope helps.
Apr 16, 2011 | Jeep Grand Cherokee Cars & Trucks
Turn signals dont work most of the time. i cant find the flasher module
your Flasher/turn signal relay are malfunction,it suppose to have a regular clicking sound everytime you use the flasher/turn signal switch, you need to replace with a new one,but you need first to check your bulbs, the RELAY located on the left driver side under the dashboard, or turn your flasher so that you can here the clicking sound....
Feb 05, 2011 | 2002 Jeep Grand Cherokee
All turn signals on my jeep cheroke laredo are not working. Is the problem a bad fuse??
COULD BE BLOW FUSE.FAULTY TURN SIGNAL SWITCH OR FAULTY TURN SIGNAL FLASHERS WHICH IS LOCATED FUSE / RELAY BOX JUST LEFT OF THE STEERING COLUMN.
Dec 05, 2010 | 2003 Jeep Grand Cherokee
My turn signals and hazard lights were working intermitently. now they have stopped working completely, the multi function switch for the lights is working as i checked it with an ohm meter. the fuse is...
The turn signal flasher is located above the fuse box under the dash on you drivers side of the vehicle. It will look like astandard relay. It is in the top row center. Hope this helps out.
Best of luck
Jun 15, 2010 | 2001 Jeep Grand Cherokee
My signals and flasher quit working 2002, Jeep Grand Cherokee
in your vehicles owner manual, look up fuses, and flasher units or flasher relay. Fuses are normally located under the dash, but when both turn signals quit working it is usually the relay. The relay is located under the hood yours owners manual should show you the location.
Oct 27, 2009 | 2002 Jeep Grand Cherokee
My turn signal and flasher wont work.i replaced the lever on the
A flasher can be located in the fuse panel, under the dash in the wiring loom, in a glove box,\ or, under the hood.
Most flashers are located under the dashboard on the driver's side.
Jun 24, 2009 | 2004 Jeep Grand Cherokee
Both turn signals do not work
Check the turn signal flasher, I believe it's located on the fuse block. Curt
Mar 11, 2009 | 2000 Jeep Grand Cherokee
Blinkers not working
Did you check the bulbs? If one bulb is burned out, the blinkers won't word on that side. You could have one bulb burned out on each side. Start the car, put left signal on. Check front and back lights. Is one light on but not blinking? If that's the case, the light that's not on at all is burned out and has broken the circuit so the good light stays on and won't blink. Check the other side. You also have a 'flasher' , actually 2. One for emergency flashers, one for the turn signals. It could be that the turn signal flasher is shot. You just have to unplug it to remove. It's probably located near the fuses. good luck countrycurt0
Aug 10, 2008 | 1999 Jeep Grand Cherokee
Car Audio & Video Logo
147 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Pierre Laplante
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
