Question about Sony Cyber-Shot DSC-P200 Digital Camera
My lens r stuck
The lens is stuck on my camera
    President:
  • 1,197 Answers
If ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 30, 2009
My lens will not come out?
Fixing a Lens Error - Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/.../fixing-lens-error-on-digital-camera.html
Dec 22, 2007 - Many camera makers will not honor repairing this problem under ..... i can view my pictures, and the lens does not come out, but when i just turn ...
Contact Stuck in My Eye: Please Help! - AllAboutVision.com
www.allaboutvision.com > Contact Lenses > FAQs
This can help "draw out" the stuck lens to the center of the eye where it can be easily removed. ... When the Contact Stuck in Your Eye Won't Come Out. If none of ...
Camera lens stuck? How to fix! - YouTube
? 3:01
https://www.youtube.com/watch?v=vJ6PLb21enY
May 31, 2011 - Uploaded by gearlock trinity
My camera telescopic lens was stuck and I fixed it, hope this helps! ... and I try it but won't work! and the ...
Jan 17, 2016 | Nikon COOLPIX L820 Digital Camera Deluxe...
Camera lens cover won't open when you turn the camera on. Says "power off then on" but still stuck
This kind of problem occurs if camera dropped on floor that broke lens mechanism OR lens mechanism got dust particles that make it stuck.
Usually lens mechanism needs to be replaced to solve the issue, however, user level try to solve the problem is to tap camera on your palm a few time gently that may release stuck lens mechanism and it start working again, if that does not help then lens assembly will be replaced.
Thanks.
Jun 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck
If the battery is fully charged, and you are able to turn on the camera but only the lens wont come out, then try doing this:
1. Hold the camera from your right hand with the lens facing down.
2. Hit the base of the camera to your left palm as you press the ON button to turn on the camera. Do this a couple of times until the lens comes out.
Chances are, your camera's lens is stuck inside because of some granule of sand or dirt stuck on the sides of the lens inside. Goodluck!
Oct 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck in out position
Replace the camera lens. Or take the camera apart, rebuild and clean the lens, then reinstall the camera lens into your camera. Rebuilding is not as fun as it sounds.
Nov 12, 2008 | HP Photosmart M527 Digital Camera
Lens Error
Hey Joy_2008,
A lens error usually means something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. You could also try placing the camera on a flat surface with the lens pointed up. While holding the shutter button in turn on the camera. What this sometimes does is force the lens to move before the camera shuts down, and when the lens moves hopefully it will dislodge whatever is stuck. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 30, 2008 | Casio Exilim EX-Z77 Digital Camera
Lens stuck
I just wrote a warning about these "telescoping lens" cameras, You need to get the lens back on track. maybe steady pressure, applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body.
May 12, 2008 | Nikon Coolpix L11 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
114 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
