Question about Directed Extreme XA-5001 150W x 1 Car Amp Car Audio Amplifier
The fuse in the red wire that connects to the battery blows everytime i connect the negative and positive up 2 my battery. it blows when i dont even have the red chord hooked up 2 the amp. whats the problem
    President:
  • 1,348 Answers
There must be a short. hook the power amp up to a power supply or another battery,fused of course...if it works,it is ok.
then the problem is in the car
high power amplifiers should be run off a secondary battery.
a 480 watt amplifier will pull 40 amps of current. enough to run 8 headlights.the real problem is surge currents,which the spikes can damage the alternator/regulator.these can top 100 amps.
some high end installs use a second alternator and battery.
Posted on May 13, 2009
  • 655 Answers
Hello super11dt,
Sounds like the power and ground wire are shorting. Check the power wire with a multimeter. Sometimes, the insulation gets rubbed off and it contacts the vehicle metal causing a short. The solution is to pull a new wire and install a grommet or bushing wherever it goes through the firewall.
Actually, the negative (ground) wire should not be run to the battery at all. It should be secured to the metal of the vehicle as close to the amp as you can get, preferably within about 3 feet.
Hope this helps.
How do I install a Maxon MCB-30 in my pickup truck ? It has 2 wires a Black/Red & Red wire. The Black/Red wire is labeled Negative, The Red wire has a fuse on it.
It is very simple . Connect the black/red wire to chassis ground (the body of the truck). Then connect the red wire to your fuse box. The truck battery would be the best place to make connections as it acts as a filter to filter most engine noise that may occur. Connect the red wire to the positive side of the battery and the black/red wire to the negative side of the battery.
Jul 26, 2015 | Maxon Radio Communications
How to wire Lumax Intensifier 3 without cigar plug
It looks fairly straightforward.
Red and Black go to the Positive and negative, (It's best to have the switch on the negative side).
The Lights themselves look like they come in two groups, the Left and Right, controlled by the Orange and Blue wires respectively. Both can be added together to the Red connection if a switch will be used to turn them on and off (Using the negative side), otherwise, another switch is necessary or the one you have must be used between the positive connection and/or positive leads to controll this positive signal input.
The yellow, (and white if included) are not necessary.
The Green one just brightens the lights, (like the brake light over the flashers, is brighter).
Notes:
- LED lights only work when hooked up with the positive and negative in the correct order. A LED (Light Emmitting Diode) will not light up if hooked up backwards.
- Generally, the positive and negative (red and black) will be connected to the power source all the time, and the signal wires, Blue and Orange will be intermittently hooked up to the positive (red), to switch on the lights using an internal transistor switch, but the same can be achieved if the positive and the signal wires are attached to the positive together, then either the negative or positive attachement to the cars power is switched using the switch you already have..
-Do not connect the lights in series with the other lights; connect all the positives, (and signal wires) to the positive, and the negative wires to the negative source. The fuses will only handle the system they were designed for.
Feb 25, 2014 | Lumax Intensifier Vehicle Emergency Led...
In my 1980 Fiberform, I have no power to any accessories or to my ignition, and my battery seems to have a full charge.
Check battery connections. Check voltage at fuse panel. Should have same voltage as battery. If voltage is present turn on any switch, if voltage goes away with a load follow the no voltage procedure but leave the switch on while testing.
If no voltage, check for any fuses or circuit breakers in the supply wires. Still no voltage: connect voltmeter red lead to positive at battery, black voltmeter lead to negative at fuse panel. Voltage OK problem is with positive supply to panel. If no voltage connect meter red lead to positive at fuse panel, meter black lead to negative at battery. Voltage OK problem is with the negative supply to panel.
If fuse panel is supplied voltage from the ignition switch start the voltage tests at the ignition switch.
Sometimes the positive and negative supply for the fuse panel are connected at the engine. Usually the positive at the starter solenoid, if so use that source instead of the positive battery post. Voltage must be traced from the root source to the load. Both positive and negative must be isolated and verified separately. Without one, positive or negative, there will be no voltage at the load. The load being whatever needs voltage applied to function, (light, pump, etc.)
If there is a corroded connection or wire it is possible for voltage to pass through the corrosion with no load. When a load is applied more amperage is required. The corrosion is not a good enough conductor to carry the required amperage and the voltage goes away. This corrosion can be at a terminal connection, (wire to switch, battery cable to battery lug, battery lug to battery post, etc.), internally in a switch, wire, fuse or circuit breaker. It is possible for a wire to appear to be in good condition. The outer insulation can be intact while the inner conductor is corroded, sometimes turned to green powder. This is why marine grade wire is more expensive than standard wire. Marine grade wire is tinned copper, copper conductor electro coated with tin to resist corrosion.
Oct 05, 2013 | Spectrum Color Fiberform, 1980-1985, White...
Simple horn diagram for 19ft. ski boat
One lead is power when button is pushed the other ground.
Jul 26, 2012 | Boating
My 89 civic lx keeps blowing the battery fuse everytime I connect the battery
My first guess would be a short inside the alternator, so if you have replaced it, look for a shorted wire in the harness.
Disconnect the wires from the alternator and everything connected to the battery, then connect one at a time until the fuse blows.
Could be a problem with the starter solenoid too.
Jul 03, 2012 | 1989 Honda Civic
It appears the polarities on my original 2008 yamaha r1 battery are not correct is this common. I removed it and put it on a battery tender. The red hot wire only reaches the negative connector on...
If the cables fit fine before you removed it and now don't, either you are putting the wrong battery back in....or you need to turn the battery around so the terminals are close to their proper cables.
Never reverse the cable connections,
Apr 02, 2011 | 2008 Yamaha YZF-R1
This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
I need a detailed instructions on how to connect a toogle switch to a fuceable link to a battery and to a halogin headlight bulb?
Ok there are 2 ways todo this ,, the first is the easiest but not the cleanest..
First ..
1.) connect 8 guage wire from postive battery terminal to (2 port fuse holder)..
2.) from each of the fuse in the holder connect to the positive lead of each bulb (which should be in the bulb holder and in the headlamps or fogs or whatever).
3.) connect negative to a bolt on cars body.. Lamps will come on..
4.) remove positive from battery terminal..
5.) connect to your spst switch (what ever kind of switch u are using.)
6.) mount switch inside car,
7.) connect wire from other lead of switch to battery terminal..(pos)
Switch the lamps on and off using the switch..
Second method..
you will need
2 4-pin relays
8 guage wire
tester
1.) remove connectors from both head lamps
2.) turn on head lamps and test to see which is positive on each
3.) bridge this wire to the Com on the relay .. (1 head lamp to 1 relay)
connect positve wire from battery termial to relay (each relay seperate wire)
connect negative wire from cars body to relay (each relay seperate wire)
4.) connect Out from relay to Positive on Halogen bulb
6.) connect negative from bulb to cars body
now the lamps will come on and off with the head lamp switch..
Alternatively you can connect the fuse holder to the battery, and connect a switch to that and then that to the positive in on the relay..
Sorry I dont have any diagrams didnt have the time to draw one,, answered this quickly this morning before work..
Sep 08, 2010 | Lincoln Mark VIII Cars & Trucks
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Jensen CD4610 CD Player
Car amp re conecting the the battery
Hook up the battery, (the negative post) and then put the fuse in. This is the best choice because if you put in the fuse and then put the negative post back in and the wires slip when putting in the negative post, the fuse might blow due to the sparks. You will then need to get another fuse, which also mean sending more money.
Dec 04, 2007 | Scosche Industries EFX Amplifier Wiring...
Car Audio & Video Logo
95 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
