Question about HP LaserJet 1320 Printer
Mirror copy - HP LaserJet 1320 Printer
  • 21 Answers
This feature is in the printing preferences.
Posted on May 26, 2009
I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
Every time I use my Gestetner to copy, copies come out with lines near the bottom of page.
first you take one print out from your computer see weather the same lines is thir or not if you find the that the print out is good you have to cleane the opticus (Eg. exposer glass reflector 1st mirror 2nd mirror 3rd mirror) - thanks
Mar 12, 2011 | Gestetner DSm615 Digital Imaging System
We have a dark vertical lines on our copies on the Lanier 5613
It appened when you take a copy????? If so, you probably hava scanner mirror durty.
Lift up de feeder end you see five screws.
Unscrew them and you have access to the mirrors.
Just wipe gently to avoid moving the mirrors
Feb 14, 2011 | Lanier Office Equipment & Supplies
Xc830 copying dark ,down center of page
There are a series of mirrors on the carriage that moves back and forth under the original glass. When dust builds up on these mirrors it makes the copies darker. Since the dust is blown by the optics cooling fan it does not collect evenly which causes areas of the copy to be darker than the others. On this machine you just have to remove the original guide plate which is the plate with 4 screws in it and has the document size numbers on it. Once that is removed the glass can be lifted out. With the power turned off just gently pull out the scanner bar. The part that initially comes out has 1 mirror as well as a silver reflecting strip on it. Clean both. Now the assembly that follows the first assembly out has 2 mirrors on it. 1 facing downward and 1 facing upward. Clean these 2 mirrors. Re-nstall the glass and plate. Turn the machine on and let the scanner unit home itself. Once warmed up make a copy to test. Cleaning these surfaces will usually correct the problem. There are 2 more mirrors under the black box under the glass but those do not get as dirty and they are harder to get to.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Xerox 8830 Copier
Can you use mirror image when copying? I have a HP L7680
The copy function does not support mirror images. I'd scan it and manipulate a mirror image with photo software and then just print it.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Hello cannon gp215ge, the first copy is I
Sounds like you have a bad drum. If a mirror was dirty, all prints would be light.
Sep 25, 2009 | Office Equipment & Supplies
How do I make a mirror image of something I am copying on a HP PSC 1610 Al In One?
you cannot mirror image while copying only on printing, under Basic tab on your properties you can select the mirror image from there.
sorry about that
cheers
Aug 11, 2008 | HP Office Equipment & Supplies
Bad copies
This seems an easy one the first problem you are getting is that the paper pickup rollers are worn or just dirty easy way to clean them is to place one piece of paper in the tray and at the leading edge spay on some cleaning fluid about a inch wide. Then press the copy button and the machine will jam. Open the door and repeat a few more times. Once finished remove sheet of paper from tray and wipe dry.
The other problem is merely down to dust on the copy mirrors. Remove the top glass normally two screws on the right hand side of the copy glass. Once removed glass place in safe place. In the machine use a cloth on the mirrors you can use windowlene or some other kind of glass cleaner. (DO NOT REMOVE MIRRORS) clean all then clean glass and replace the copy should be clean. (NOTE!!!!! There should be about six mirrors so make sure you clean them all)
Oh and be careful machine should be off when doing above.
Hope this helps
J
Dec 25, 2007 | Office Equipment & Supplies
Canon 6025
Your problem is most likely caused by dirty optics. Place a sheet of paper on the glass & make 1 copy with the lid up. Look under the glass at the mirrors on the scanner & see if there is any dust on them. If so,turn the copier off & unplug it from the wall, remove the glass & wipe off the mirrors with a DRY cotton rag. There are 3 mirrors on the scanner assy. There is also three mirrors under the lens cover that should also be cleaned. After cleaning the optics, make a test copy.If your copies are still to dark, press the additional functions key & select exposure adjustment. You can lighten/darken all copies by changing this setting. If you have any problems or questions my email is bspier@carlsonsupplies.com Good Luck!!
May 29, 2007 | Canon NP 6551 Black and White Copier
HP LaserJet 1320 Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
