Question about HP LaserJet 1320n Printer
HP Laserjet 1320 Paper feed malfunction
I've been using this printer successfully for quite a while.  A couple of days ago the paper feed stopped working.  The printer works because I can hand feed single sheets of paper through the upper feeder that I usually use for printing envelopes.  What isn't working is the spring that raises the paper up to the feeder.  I can manually trip it.  But when I slide the tray into the printer it will not release.
What (short of buying another printer) can I do?
  • Anonymous Mar 18, 2014
    printer won't release the first sheet of paper after it prints
  • Anonymous Mar 28, 2014
    I have a 5 x 8 inch index card which the normal paper tray will not handle. Do I remove tray to feed by hand?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Posted on Oct 18, 2007
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
I want my hp laserjet 1320 to print front and back
Make sure the manula paper feed slot is closed.
Access Printer Properties or Printing Preferences
Select the Finishing Tab
Select Print on Both Sides
Select OK
Then print the document(s)
Nov 10, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
Paper jams
check the feed roll
Oct 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
1,027 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
