Question about Memorex MMP8595 MP3 Player
Gets stuck on "playlist generating please wait..."
When i disconnet the player from the computer, it gets stuck on the message: "playlist generating please wait..."
I ADDED SONGS TO MY COBY MP815 USING WINDOWS MEDIA PLAYER AND NOW IT WONT TURN ON. I PLUG IT INTO MY COMPUTER USING MY USB AND WHEN I UNPLUG MY USB FROM THE MP815 THE SCREEN FLASHES WHITE FOR A QUICK...
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
Jun 23, 2010 | Coby MP815 Digital Media Player
No playlist in the storage media. I use media player 11 but can only get the songs into a folder, not a playlist.
Hi beanfromex,
I've heard many people complaining that they can't make a playlist with media player. Certain other free programs like Media monkey can help. However, the simplest thing you can do is go to the folder on the walkman, select all the media files you want to add to a particular playlist, right-click and then select "Create Playlist". A .pla file will be generated immediately.
Oct 19, 2009 | Sony NWZ-E438F Digital Media Player
Downloading music to my MP3 player, how do I do it. I have the music on my computer and I move to the MP3 player but when I disconnect it does not display on my MP3 player
For transfers to Sansa Clip see page 11 of the pdf manual [page 9]:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When using the drag and drop method in Windows
music has to be dropped in the Music folder of the player.
Using Windows Media Player 11:
In Library or Sync mode:
1. Create a playlist e.g. "MyPlaylist"
2. Put music in the playlist
3. Save the playlist
In Sync mode and the player having connection:
4. Move the playlist e.g. "MyPlaylist" under / to the device
5. Start synchronizing with Start Sync
6. Wait until al files have been transferred:
a message appears when you can disconnect .
When you need more help just post a comment.
Sep 23, 2009 | SanDisk Sansa Clip MP3 Player
How to operate sansa and creating data base
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Transfer media
A guide in how to transfer media for the RCA Opal M4001 see this manual in pdf format: manual for RCA Opal M4001
For more help on for this device see the support site:
support for RCA Opal M4001
When using Windows Media Player 11, a short description how to deal
with putting media on the device:
Note; convert video with the RCA video converter on the computer
before transferring it onto the player.
A download can be acquired with the next link:
download RCA video converter
1. download the execute file
2. install the converter by clicking on the execute file:
" rcasmvconverter_v1.6.2.0.exe "
Sep 12, 2009 | RCA OPAL M4001 MP3 Player
RE:WINDOWS MEDIA PLAYER 11 IN VISTA
Does your player show up as being connected in WMP11
Sync mode ? If not, a firmware installation for the player is needed.
If yes, did you perform doing next actions ?
Sep 04, 2009 | SanDisk Sansa e250 MP3 Player
How do you add a playlist to the player!!!
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
Jun 30, 2007 | SanDisk Sansa m230 MP3 Player
Memorex MMP8595  MP3 Player Logo
126 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
