Question about Daewoo DW500M Top Load Washer
Agitator keeps coming loose and off on the daewoo "dwf8094r"
The top screw on the agitator to screw down and hold it inside the washer keeps coming loose. do i need to put some locktite glue on the screw or am i missing a small clip ? it still has the c clip and screw any information would be greatly appreciated . cheers chad titus.
    Sergeant:
  • 138 Answers
Locktite would be an excellent solution.
Posted on May 13, 2009
Lg waveforce top load washer that is around 3yrs old. The agitator plate hold down screw (under the chrome cap) keeps coming loose and at the end of the wash the plate is up with clothes under it.
Remove the screw and look underneath the agitator, GE machines have a correct way to put them back so the agitator sits at the bottom of the machine with virtually no gap. Tighten the screw hard. Perhaps you lost a locking washer at some stage?
We moved to front loaders.
Oct 24, 2015 | LG Washing Machines
PAV2300 agitator bolt keeps coming loose
Loctite sounds the order of the day. Don't overtighten once the thread lock is in place and allow to cure before using machine.
Apr 23, 2012 | Maytag PAV2300 Top Load Washer
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How can I remove the agitator inside my washer, there is no screw at the top and it wont just lift up and come off.
HI jescatlicea,
To remove the agitator on your washer you must first remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife. Under this cap there actually is a screw/fastener, it just doesn`t look anything like a typical screw. It is a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it, I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose.
Hope this help`s you to get your agitator off without too much agitation...;)
On Kenmore full size washer`s built by whirlpool there are one 2 types, ones with a 7/16" bolt holding it in place, and the type I described. They are by far the most common, although for short period`s in the past kenmore had full size washer`s built by GE as well as Frigidaire/WCI.
Thank`s for visiting "fixya". Good luck and let me know if I can assist you further.
macmarkus :)
Jan 27, 2010 | Kenmore Washing Machines
Agitator came apart while doing laundry
There is a bolt that holds this together that screws into shaft. Is the upper agitator broke? Or the ratcheting part in the center? Give full model number to further assist you.
Jun 15, 2009 | Kenmore 15864/15862 Top Load Washer
Washer will not agitate.
Pop the top cover on the agitator.
Remove the screw inside.
Remove the agitator and inspect it for damage where it attaches to the transmission shaft.
Feb 24, 2009 | Kenmore 23822 Top Load Washer
I have a Roper RAX7245BWO that the top of the agitator is loose and doesn't agitate. I know I need to replace the cam dogs. What I can't figure out is how to get the inner cover (part #20 on the agitator...
take the disp out, remove the inter cover, take out the 7/16 screw, pull agit up from bottom to take out of washer, set on floor, put feet on bottom of agit and hold top fins and pull up hard and quick, will come apart, after putting new dogs hold agit upside down to put back together or dogs will keep falling out and put back together / please remember to leave a rating / have a good day.
Nov 27, 2008 | Washing Machines
Agitator
there should be a 7/16s bolt under the cap try tightening that up
Mar 21, 2008 | Washing Machines
Loose agitator Maytag LAT2600AAE
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Dec 17, 2007 | Whirlpool LSB6200PQ Top Load Washer
Daewoo DW500M Top Load Washer Logo
158 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
