Question about Epson EPL N2050 Laser Printer
How change ip address of epson epl n2500 - Epson EPL N2050 Laser Printer
  • 2 more comments
  • pilyu957 May 13, 2009
    they have already ip address,but we need to change the settings of ip address because it will same gateway here in our shop. it will buy 2nd hand,so we need to change the settings,how?
    sir my problem is how to change the old ip address,because when i ping the printer,its not found cause of different ip and gateway,thanks
  • Shishir Garde
    Shishir Garde May 11, 2010
    epson epl n2500 is a standalone USB printer as per Epson's website. It would not have any IP address.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    More detail needed.. are you on a local network? Are you getting an address conflict?
    Please clarify if you can... thanks.
    Problem Solver:
  • 11 Answers
Hi, i know its been months already but i have a solution to your problem, we have same problem and i solved it already..First, you have to get the ip address of your printer,..Then, open command prompt..
At command prompt, Try this command;
telnet ip address (this is your ip address)
Then, as you can see, their is a lot of instructions there..
So, you must follow it..
Take note: It automatically saved the changes.
Second options:
Type the ip address of your printer at web browser, it looks like this:
http:/192.168.1.100/ (this must be your ip address)
Then, as you can see, there is a lot of choices there.
So, you have to choose the configuration to change your old ip address.
I hope it can help you..
Thanks
Posted on Nov 13, 2009
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
DRIVER FOR EPSON EPL-5900L
Try to click this link for your reference. http://driverscollection.com/?H=EPL-5900L&By=Epson. Hope this will helps. :)
Jul 12, 2011 | Epson EPL 5900L Laser Printer
I need driver for laser printer Epson EPL-5900L for windows 7 thanks
Epson do not support this printer in Windows7 my advise is try running the setup in compatablilty mode if you have the Pro/Ultimate version
Aug 06, 2010 | Epson EPL 5700L Laser Printer
Driver Epson EPL-5700L for Vista
I would try using the regular 5700 driver for vista and if that don't work then try using the 5700L driver for windows XP cause there shouldnt be much of a change from the XP driver to Vista driver.
Mar 25, 2009 | Epson EPL 5700L Laser Printer
Epson EPL N2050 Laser Printer Logo
936 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
