Question about Intel Motherboard
No power in mother board - Intel Motherboard
  • Dick
    Dick May 11, 2010
    Need more information. Do you have a power supply? Is it plugged in? What have you tried? Has it ever worked? What changed? What computer? What motherboard?
    Problem Solver:
  • 5 Answers
I can fix that problem just change the atx power connector
Posted on May 13, 2009
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
When i press power switch, mother boards power became off.
mother board problem.. u have to change ur mother board or u can do 1 thing just open the restart connection.form the mother board.
Mar 29, 2011 | Intel D845GVSR Motherboard
WHERE TO PUT HARD DISK POWER PIN IN MOTHER BOARD
The hard disk power cable is to be connected to the power cables that comes from the SMBS. And only the data cable is plugged on to the Mother board
Mar 11, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
