Question about Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo
Toshiba tv keeps burning fuse
A lightning shot down my tv, I oppened it up and found a burned fuse 125 v 6.3 amps.  Couldn't find an exact match but tried with 125v 6 and 7 amps, but it keeps burning it. Can someone please find a solution for me?
0 characters
1 Points
I just got a 2004 GMC the TV and DVD player no power at all what can I try?
try check :
1.your socket for connection (wall power socket) propbably some palstic burn/ disconnected parts
2. check your device power cable.. (might be broken)
3. check th fuse in the device...(fuse might burn)
Lastly.. your m/board (power circuit might burn)
Oct 31, 2013 | DVD & Blu-Ray Players
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
No disc found
i would try lens cleaner cd and is this likea store rented dvd also not a copy burned one or thx nick
Feb 09, 2008 | Toshiba SDV593 DVD Player / VCR Combo
Dvd player shows no sign of power, wont switch on, or eject tray.
If it is black or discolered, yes, it is probably shot. I had the same thing happen to my Sony woofer.I found a replacement ironicaly, at a True Value store. We equated it to a power surge. Cost me about $5.00. It is now good as new.
Dec 02, 2011 | Cyberhome CH-DVD 300 DVD Player
Stopped working.....does not turn on.
your dvds samps switch mode power supply has some complaint. remove the power and oppen its cover and check the fuse inside.if it found blued, maybe the smps driver mosfet or the MOV aftre fuse may be damaged. MOV is a component which blues the fuse if there is an over voltage surge over the specified limit. if found faulty replace it.
Dec 15, 2010 | Craig DVD & Blu-Ray Players
We had a lightning strike which hit the house phone wire and knocked it out. the tv and dvd player didn't get hit. we turn the dvd player on it plays but no picture. the input button on remote won't switch...
Check the TV internal fuse. If fuse is OK check the SMPS. Lightning damage could harm any part and step by step only it can be found.
If you have insurance for your TV and other appliances, you can claim.
Better contact the authorised service provider for assitance.
Aug 27, 2010 | Zenith DVB712
Trying to dubb video from hard drive to dvd-r and error 14 keeps coming up on the screen. thanks sylvie
Well, by now I'm sure that you know to clear the code, you press the "Display" button a few times. As for getting the Toshiba to actually burn a DVD, I'm not certain that I can help you there, as I've run into problems burning stuff. Unfortunately, it doesn't burn all the time, even if you use the same routine as the last successful burn.
Sep 26, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba dvdw/hd ts-l802a double layer dvd burner will not burn dl dvd's, laptop Acer Aspire P920G, win Vista premium
I have the same toshiba burner. You should manually assign a right sector number to a so-called break point between layers of a DVD9, in order to start burning, or to burn successfully with this Toshiba. This requires profound knowledge, and special progs to use. "Imgburn" (freeware) is one of a few.
Jul 12, 2008 | DVD & Blu-Ray Players
Toshiba MW27FP1 27" Flat TV/DVD/VCR Combo Logo
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
