Question about Logitech 980374-0403 Consumer Headset
Can't use Headset for PS3
Microphone dosen't work, I don't know why, and I don't know any more details. I use it for PS3, and it lights up and stuff, but I can't use it, and in the Audio Device Settings, it dosen't show that I'm speaking into the mic.
I haven't tried it on any other machine yet too see if it's the headset or the PS3, but my headset is pretty beat up, so I'm thinking weiring, but it all seems to be intact.
praky16
  • 744 Answers
SOURCE: logitech headset not working
did u connect both the output wires from ur headset to ur system audio port.?
Posted on Feb 08, 2009
SOURCE: Crackly Headset
I had same issues but hadnt bothered install the driver cd that came with headset I had let XP find it.. so just installed the CD and had to upgrade to latest windows messenger, then replug ur headset in or pull out and reinsert usb and all should be fine :)
Posted on Feb 15, 2009
SOURCE: I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Posted on Jun 29, 2009
SOURCE: My logitech headset was working and I was using it
The red light indicates that the headset mute is on. Press the center insert on the right side headset and the light should go away and the distant end should now be able to hear you.
Posted on Jul 19, 2009
SOURCE: mic on ps3 headset does not work
how do you pair it ... my light wont turn purple...
Posted on Dec 27, 2009
How do you connect to the ps3?
*NB: it will ONLY work for communications, NOT for game audio. (lame az, I know!)
  1. hold in the headset's power-on button until it flashes red/blue for pairing.
  2. Next make the ps3 scan: settings> accessories settings> manage bluetooth devices> register device (yes)> scan and add. (probably passkey 0000)
How to connect any Bluetooth headset to your PS3
Dec 25, 2013 | Creative WP-350 Headset
How do I get my bluetooth on my cell to pair with my playstation 3?
1st option: Here's what you'll need to do.
On the XMB on the PS3, go to Settings, then go to Accessory Settings, then Register Bluetooth Device.
Select Register Headset/Microphone/Headphones.
Press X to accept the 'Start Scanning' mode for the PS3. Then....
With the Motorola pairing can be clumsy. It involves pressing and holding the call button while the
microphone is folded closed, then quickly opening it up once the blue LED comes on.
2nd option: Hold down the answer call button on the bluetooth headset until the light is solid (not flashing). When the PS3 detects your headset, it'll ask for a pass. The pass should be "0000" (four zeros).
Aug 20, 2011 | Motorola Cell Phones
Why cant anyone hear me on my turtle beach headset for ps3?
could be your settings try to monitor your own microphone when you talk. could also be break in the microphone cable. check the its plugged into red socket not pink it should have a microphone symbol
Mar 02, 2011 | Voyetra Turtle Beach Ear Force X3 Wireless...
My ps3 head set has said paired but not working , why . this 2 one ive got same problem.
The headset only works for games that support headset communication.
With that in mind, after you successfully pair a Bluetooth headset with your PS3, you need to verify that it's currently being used by the system.
- - - - - - - - - Skip this section if you've paired the headset already - - - - - - - -
To verify that the headset is paired, go to:
XMB (main menu) > Settings (second icon from the left) > Manage Bluetooth Devices (5th icon down) > [name of your Bluetooth headset] under Device Name with a blue dot next to it
-If you don't see your headset under there, select "Register New Device" on the bottom of the screen and follow the prompt
-If you see the device name, but the dot to the left of the device name is black and not blue, turn on your headset and on your PS3, highlight the headset device name and press the Triangle button and select "Connect"
Finally, to verify that your headset is being used by the system, go to:
XMB > Settings > Audio Device Settings (7th icon down)
From here, make sure that the Input Device shows the name of your headset's device name- if not, highlight Input Device and press Up and Down on your controller to select the headset.
Next, you will do the same thing for Output Device- select your headset device name if it is not shown.
Once your device name shows in both Input and Output Device areas, you can talk into the headset and you should be able to hear yourself. Adjust the microphone volume by changing the number next to "Microphone Level". The bars on the top of the screen in Audio Device Settings should move and respond to speaking into the microphone.
Finish by selecting OK on the bottom of the screen to save your settings. Don't hit the Circle button or else the changes may not save!
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I want to hook the plantronics 367 headset to my ps3 for chat and gaming purposes but the ps3 only has USB ports while the headset only has 3.5 mm jacks. one Jack is the audio and the other is the...
I'm sorry but per Plantronics the Gamecom 367 headset is not compatible with the ps3. The Gamecom 777 will work with the ps3.
Here is a link for more information on the Gamecom 777.
Good luck from Headsets Direct!
Feb 13, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Is the steelseries 7h usb headset compatable with the ps3
Hello Sixlittledev,
Although the 7H USB headset is not natively supported by PS3, you may be able to get it to work if you have a headphone jack in your TV.
You will need to connect the headset in the following manner:
Headset microphone cable -> USB card -> PS3
Headset audio cable -> 3.5mm extension cable -> TV headphone jack
Although we do not guarantee compatibility and this method is a bit cumbersome, you can get it to work this way.
Mike S
SteelSeries Support
Http://www.steelseries.com/support
Dec 03, 2010 | Steel Series Steelseries 7H USB Headset...
My motoriola H710 headset is paired, but no one can hear me
The microphone no longer works. Don’t know if you can change the Microphone of your headset through some authorized service personnel or not.
Jun 04, 2010 | Motorola Mobility H710 Bluetooth Headset
MOTOROKR S9 has microphone but not sound with PS3
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks....
Jan 28, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Computer wont recognize me Saitek GH20 Headset
I have the same problem. I suspect that this headset is not USB compatible at all. It possibly only uses the USB connection as a source of power (for the vibration effect). This is a problem for me because I wanted to use the headset on a PS3. Saitek don't claim that it works with the PS3, but the claim of USB compatibility is ambiguous and misleading in my opinion.
Feb 20, 2009 | Saitek GH50 Headset
Headset problems
check ur driver ,microphone cable ,pin, condenser microphone ,and socket
Feb 18, 2008 | Shure Head Set Microphone Microphone
Logitech 980374-0403 Consumer Headset Logo
596 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
