Question about Microsoft Xbox 360 Arcade
Xbox 360 needs repaired
I tried all the possible solutions, my xbox 360 needs repaired
  • Daryl
    Daryl May 11, 2010
    Have you contacted Xbox repairs?
    Problem Solver:
  • 6 Answers
Go to http://www.scratched-disc-repair.com/ this will fix any disc u need fixing and cosoles can be fixed at a very low price. i used this when i moved my xbozx whilst playing fifa 09 and they reapired the disc for just £3.95 when it had a massive scratch in it, on the website have a look around and you will find hat you need.  thsnks Alex
Posted on May 13, 2009
  • tackzer2dubb
    tackzer2dubb May 13, 2009
    on the website i told u about earlier go to services and at the bottom will be a section that tells u about cosoles reapirs click order and it will take you to the next step
No audio video and the red ring light flashing,MY UNIT IS XBOX 360 CONSOLE
Dear,
You have technical fault which needs to be repaired. You can try this Microsoft Xbox 360 Easy and Complete Fix Manual - A Do it Yourself at Home Manual.
This xbox repair manual is very useful and includes many diagrams and instructions for your easy understanding. Moreover, the prices are CHEAPER and you can save time and money by repairing your unit yourself and save money on sending it to several repair shops. I tried it myself and found it very useful. The customer support department is very helpful as well. I hope this information would help you find a better solution to your problem :)
Aug 04, 2011 | Microsoft Xbox 360 Console
How to fix the red rings on your xbox 360
1 Red Light Error -
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights Error - One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights Error - f you see three flashing lights, you are experiencing the infamous three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the warranty
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Jul 21, 2011 | Microsoft Video Game Consoles & Games
The console won't read the disc. What do i do?
If your console wont read your disc then there is an issue with the disc drive in your xbox 360. The most common failure responsible for this issue is the laser going bad. If your xbox 360 is still under warranty than you can contact Microsoft directly regarding the issue. If not you can replace the laser manually. Below is a link to a Youtube walk through on how to do this.
http://www.youtube.com/watch?v=5XiYSV9ztVU
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Microsoft Xbox 360 Console
My xbox gets stuck in the middle of a game
Xbox 360 screen freezes are some of the common and frustrating problems that Xbox owners have had to deal with since the launch of this top notch gaming machine. More often than not, a lot of the searches occur on Google by people looking for a quick solution. But to keep from getting some unrelated information, its a good idea to understand why your Xbox 360 screen freezes in the first place. This will help you to focus your search and also make you able to spot all those tricksters with bogus promises that tend to be unreliable, and possibly hazardous to your Xbox 360 game console.
Gamers have to understand how to repair the screen freezing on their systems before it becomes a much bigger situation. One of the biggest culprits for this problem is heat. Heat build-up can easily ruin any machine with movable parts and the interior of the Xbox 360 is conducive to producing a lot of heat. If you look inside an Xbox 360 you should be able to notice just how crowded it is inside, due to its compact design. Heat producing components are placed side by side, and really just too close to each other. This is what prevents the adequate amount of air circulation causing it to overheat and then the screen freezes. There is not much we can do about how the internal components of the Xbox 360 are aligned, but we can do something to to make it cooler inside.
So Why Does My Xbox 360 Freeze Up?
This is actually a precautionary measure that was built into the Xbox 360 system. You could call it a "fail safe" response. The Xbox 360 is designed to shut down the entire system when the graphics chip gets intensely hot. This is actually a good thing because if the gamer continues to play in that overheated state, it can easily result in frying the entire system, and starting a fire; not to mention a possible injury or burns to the user.
Knowing what causes the Xbox 360 screen freezes is only half the battle. So now that you know what causes it, the next step will be the solution. You simply have to find a way to keep your Xbox 360 running cool at all times, and there are a number of ways to achieve this. You will have to buy an additional cooling unit because the one that comes with the Xbox is almost ineffective.
I am writing this article because I had a similar problem. I looked into ways to fix it myself for cheap and came across 3 of the popular ones. I tested them thoroughly for 3 days and decided that i had to make my results public so that anyone else can learn from my mistakes, and choose the right solution the first time, and not by trial and error.
During my tests I realized that the solution that worked for me was an Xbox fix guide written by Chris Jones and his team of Xbox repair professionals. It was a much cheaper solution which allowed me to fix xbox 360 screen freezes permanently on not just my Xbox but my friends as well. http://xbox360fixx.allnewstreams.com
Aug 20, 2010 | Microsoft Xbox Console
Xbox360 2 red lights left side tv says no signal
Your console is overheating.
Solution 1: Move your console loadTOCNode(2, 'whattotry');
  1. Turn off your Xbox 360 console.
  2. Move your console to an open, well-ventilated area, away from all other electronic devices.
    Collapse this tableExpand this table Poor conditions Good conditions Collapse this imageExpand this image clutteredenvironment.jpg Collapse this imageExpand this image cleanenvironment.jpg
    Tips for positioning your Xbox 360 console
    • Don't put your console in an enclosed space. Put your console in an open area with lots of ventilation.
    • Don't stack other electronic devices on top of or below your console.
    • Make sure your console and its power supply are on a hard surface. Don't put your console on something soft (like a bed, sofa, or rug).
    • Keep your console away from heat sources, such as ventilation openings on televisions and electronic devices. Also, keep your console away from heating vents and direct sunlight.
  3. Turn on your Xbox 360 console.
If two lights around the power button of your Xbox 360 console still flash red, try the next solution.
Solution 2: Let the console cool down loadTOCNode(2, 'whattotry');
  2. Wait one hour for the console to cool down.
  3. Turn on your console.
    Note After turning on the console, you might see a message on the screen confirming that the console was shut down due to overheating. The message will say: "Your Xbox 360 console is designed to automatically shut down to protect it from insufficient ventilation"The message will also contain information about ventilation and console placement.
    Press A on your controller close this message.
uparrow.gifBack to the top Solution 3: Request a repair loadTOCNode(2, 'whattotry'); If the above solutions did not resolve your problem, or you continue to receive the message that your console was shut down to protect for insufficient ventilation even after you move it to a cool, well ventilated location, your Xbox 360 console needs to be repaired at our service center. To start the online repair process, click one of the following links:
Feb 19, 2010 | Video Game Consoles & Games
My xbox 360 does not display VIDEO buy plays sound perfectly
Check to make sure the video selector switch on the video cable is set to proper position according to your type of tv. (TV or HDTV)
Unplug your cables and then plug them back in again.
You can also turn on your Xbox using the controller. As soon as it turns on hold in the right trigger and press the Y button. This will reset the video system settings.
It may be possible that you have a bad video cable but I doubt it.
If none of the above works you'll need to call xbox support to have your console repaired especially if it's still under warranty. If it's still under warranty, (under 1yr old for this type of problem) Microsoft will repair it for free.
Aug 13, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont fully play the games
try warming up your console switch on your xbox and leave it as it is for 15 mmins. Then try opening the dvd and close it, try it few times.
You can also repair your drive with the help of xbox 360 repair guide which has solutions for people who like DIY.
you can get a copy from here and save big bucks
Jun 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 thinks it`s an Xbox and won`t register a 360 game
Hey,
Strange Issue, but I think its a possible solution to it. I would say the drive and/or laser needs to be changed.
Apr 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Three red lights on xbox 360
http://support.microsoft.com/kb/907534
Dec 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Arcade Logo
78 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
