Question about Dryers
Makes a loud clunk once per drum revolution. There is a mark on the outside of the drum and I think it's hitting the motor housing. Could this be the drum bearing? Is it worth repairing? It is a IS60V
  • chris_b_robi May 13, 2009
    Thanks Vic
    It is an Indesit IS 60V Tumble dryer
    Yours
    Chris
    President:
  • 1,136 Answers
Hi, What brand is this and model #? It does sound like a bearing or rear roller has gone bad. Yes it will be worth fixing. I cam help you. Please let me know.
Thanks
Vic
Posted on May 13, 2009
  • Victor
    Victor May 13, 2009
    You're welcome. I have never heard of that brand. Let me know if I can help you further.
The bike makes a loud noise when pedaling
I suspect the crankset or bottom bracket. It can have the illusion of tightness when not moving, but "clunk" everytime you pres on the pedals. I would first make sure that the cranks are tight on the bottom bracket axle. This will require a metric wrench.
Oct 10, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
GE dryer DCVH515EFOWW thumping noise after heats up. Recently replaced front drum bearing and slides which fixed squeaking. Now having rhythmic thumping (no squeal or squeak).
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Aug 18, 2014 | Dryers
When it hits the spin cycle the drum makes a loud clunking noise, and found some white plastic piece that came out.
Sounds like the drum bearings have gone. This is a big job to do. If the machine is 5 years old and has done a lot of work, think about a new machine as may be cheaper in the long run.
Nov 04, 2013 | Kenmore HE3T Washer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
Aug 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Thud sound, once per rotation
that do fall under defective workmanship...but you have to look in your owner manual,,under your warranty page...i know if its stainless your covered..onthejob
Feb 03, 2009 | Maytag Neptune MDG9700A Gas Dryer
Very loud noise as drum is spinning
Hi, I think that the bearings may be wearing down and need to be replaced. Or the belt may be faulty and needs replacing.
To tell if the bearings are wearing down or need replacing, turn the drum by hand when it is empty and it will make like a grinding noise.
If the belt is torn, frayed or coming off the motor you will need to physically look.
Nov 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Knocking sound
The spider on the back of the drum is most likely broken. The part should have a 10 year warranty. Labor should run 250 - 350, unless you call A&E, then it will be a lot more.
Jan 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Dryers Logo
177 people viewed this question
Top Dryers Experts
