Question about Western Digital Caviar SE WD1600AAJS 160 GB SATA Hard Drive
Configuring wd ext drive with int. hard drive
Is there any recommended way to use my ext drive with my int. drive? I am interested especially interested in editing home videos.
  • 116 Answers
Just plug that baby in.
When you format it you will have a new drive in your my computer.
From their you can use it just like your c drive. However you'll just select the (For example it comes up as F:) F:\ drive to save to.
Their are more complex ways of using the drive, and integrate it with your C:\ space. However when you have some hardware problems you could loose all the information so i do not recommend that.
What to do?
Plug in the drive then boot up the pc
If nothing comes up in My Computer then:
Right Click My Computer
Click Manage
Click Disk Manager
A little wizard will pop up, follow the instructions, and when the option comes to format FORMAT in NTFS! this is important for larger than 4gb files.
While your editing home movies you will most likely break that 4gb barrier fast :)
Posted on Oct 14, 2007
WD 1TB drive only shows up as a 10GB hard drive
WD has a courtesy Drive cloning tool from acronis. It's on their web sit under drivers. Don't worry about the "My Book" thing the file is labeled Acronis True Image WD Edition Software download.
Apr 27, 2014 | Western Digital My Book Essential 1TB...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
I plugged my wd into my dish dvr it formated, decieded i did not wanna use my 1 tera on this wanna do a smaller drive how do i reformat my wd external hard drive so that i may use it for computer stuff?
If your PC will not recognize the drive now, you will have to use an external formatter program. If it will, thenclick on the drive letter of the drive and choose format from the options menu.
Nov 13, 2010 | Western Digital My Passport Essential...
WD 500 My Book Prem Ed will not power up
If it's less than a year old, call WD and get a replacement power brick and see if that works.
You could of course also buy a replacement and see if that works.
If the unit is not powering up, the HD inside is almost certainly good. Data recovery is trivial. All you have to do is open the case(hard part) and remove the hard drive. Find a desktop you can install it into and copy the data to a new external HD. If you don't have a a desktop available, you can buy a USB to SATA adapter with a power adapter for about $15-20 that will work well. If you're creative you could probably re-install one of these kits into the existing enclosure for a permanent fix.
Jul 26, 2009 | Computers & Internet
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
My wd 12o gb ext hard drive not recoginized by my computer
This problem often happens because of the cable, try to move the cable near the connector of your drive. by this time access the devive manager, and check if there is changes in the list while you change cable's position, if so, your cable is defect.
Nov 23, 2008 | Western Digital Passport WDXML800UE...
Wrong Power Adapter
Yes.If the voltage range exceeds the limit,"astalavista baby."
If the voltage is was below recommended,try plugging in Power Only,turn on,leave for a minutes.This should adjust the voltage regulator back to normal.
Feb 04, 2008 | Western Digital 320GB MyBook Premium Ext...
Western Digital Caviar  SE WD1600AAJS 160 GB SATA Hard Drive Logo
174 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
