Back to:
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Faulty tv picture`
posted by loftypuss on Oct 14, 2007
When i switch on the set the picture is very jittery and rolls, sometimes freezing for a few secs.
After about 8--10 mins everything settles and the picture is fine thereafter.
Have done the usual switching on and off with mains and leads.
The set is about 2,5 years old.
Hope you can help. kind regards mike.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 15, 2007
Not Rated (0)
modern
Rank:Wiz Wiz
Rating: 79%, 536 votes
this is due to loose contact in power supply.
it might be due to some capacitor or print loose in supply.
please also check your plug & socket for loose.
it is not a major problem
good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on faulty tv picture`:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
I don't know how to hook up my vcr and dvd player. It...
i have a pnasonic crt tv model txw28r4dp. it goes to...
Mitsubishi WS-65819 TV
error code 22 'short protect circuit' after adjusting...
Sony FD Trinitron WEGA KV-36FS120 36" TV
when i turn on tv it goes on then off in less than ten...
RCA TruFlat 27F520T 27" TV
27inch rca tru flat tv.
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
