How to solve the lan problem
I have found many problems while networking or connections please solve my problem
    President:
  • 1,197 Answers
Tell us what ur problem is and we ll try to help you
Posted on May 13, 2009
Why does my ethernet not work properly?
In order to decide wheather it is a HW or a SW fault, try to boot another operating system, eg. some one-CD Linux testing distribution. In case it is a SW problem:
- try to instal Asus update (utilities):
ASUS Update V7.17.17 for Windows XP 32bit/XP 64bit/Vista 32bit/Vista 64bit/7 32bit/7 64bit from:
http://www.asus.com/Motherboards/M2NSLI_Deluxe/HelpDesk_Download/
- try to set in BIOS: POST Check LAN Cable: ENABLE (for both LANs). Any error message?
- try to switch off one of LANs: Onboard 1st(2nd) nVidia LAN: DISABLED. Does the other LAN work?
The last step could be testing different version of BIOS...
The easiest way to get LAN ready could be installing PCI LAN card...
May 12, 2014 | Computers & Internet
I am not able to connect the canon 3300i to my computer my lan cable . i there any way to solve the problem .when i connect and run the drivers of the printer i am getting the the error message printer ...
after you connect them use cable LAN.
find the IP address on the copier, some way you find network system on display :
press * - network system - IP address. write it then you Ping on your computer, by run.
example. ping 162.198.100.3. t (type this alphabet t after IP address) and then press OK/enter.
after connected you can install the driver..
good luck...
but before see on your computer. is there any new device detected ?
if there is it. continue step above.
May 31, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
How do I connect internet to satellite cdt4030
Hi, Can You please more details in regard to this problem... I am assuming that you reformat you Pc and you might not have lan Ethernet driver. Or the Lan is disable... To chek click start,click control panel network and internet connection if your OS is windows vista / windows 7 click connect to network .Xp network connection and find out if have lan connection if the page is blank you need a ethernet driver. Hope this info might help you to solve your problem. Have a Happy New Year... HRH
Dec 30, 2010 | Computers & Internet
I reformatted my compaq presario laptop using winXP pro, v.2002. It wasn't the original OS installer that came with the laptop, it was one my friend lent me. The problem is, the network adpater icon...
while reformating the lan drivers and other related drivers are being wiped out. so load your lan driver software again. if you find it hard to get 1, then goto www.hp.com and refer your model, then get all drivers from the site. to be more sure if your drivers are not installed,go on device manger, and check the question mark(?) with yellow colour, all those are not installed..load it
Oct 21, 2009 | Microsoft Windows XP Professional With...
With only Cat 5 UTP cable segments, the maximum length for any cable segment is 100 meters, make sure that you don't exceed this. Also crossover cables are for switch to switch connections. You must use a straight thru cable from PC to switch port
Jun 01, 2009 | Computers & Internet
Power management related query
Some system have a BIOS settings like these. There are 2 options affecting the NIC. LAN/WLAN switching and LAN power save. Are both LAN power save and LAN/WLAN switching enabled?
On my laptop, it does the same thing as your computer when its on battery (HP laptop) except when there is an ethernet cable plugged in or loopback. I made a little loopback plug to keep the port active even when it is unplugged.
http://www.juniper.net/techpubs/software/nog/nog-interfaces/html/fe-ge-loopback25.html
May 11, 2009 | Broadcom BCM5704 Network Adapter
Local Area Network UNPLUGGED...?!!!!!!!!!!!!!!!!!
You should start with checking to see if there is an updated driver for your network card. If not try removing the network adapter under the device manager and restarting the computer. If that doesn't work email me and I'll give you a few more ideas.
Please don't forget to rate!
Thanks!
Feb 23, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
