Question about Palm Treo 755p Smartphone
I want to delete all duplicate contacts on my phone.
My Palm Treo 755 has two of every contact. How can I get rid of the extra copies?
  • svhunt May 13, 2009
    How do I delete the records off the SIM card?
    Sergeant:
  • 138 Answers
It sounds like you have them saved to your SIM card and your phone so just delete the copies off of either one that you pefer.
Posted on May 13, 2009
  • Brittany Garner
    Brittany Garner May 13, 2009
    f you want to delete the contact that is in SIM, then, go into the SIM Book app and then tap on the "Delete" button at the bottom
I have four contacts coppied on my cotacts and can not delete three out of four this is on like five of my numbers.
Hello paudachristi,
The duplicate contacts can be deleted like this
•Open the copy of the contact record. (highlight the name and press the 'Palm' button)
•Press the 'Menu' icon key (Lower right hand corner next to 'ALT' key)
•Tap on the 'Edit' button (bottom of screen)
•Tap on the 'Details' button (bottom of screen)
•Tap on the 'Delete' button (bottom of screen)
Do the same procedure for each of the extra copies. I hope this helps to remove those extra contacts.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Aug 07, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Vodaphone Palm Treo 650 and when I put my CHIP into
Hi, not really familiar with Plm devices but insert your sim in to the palm go to contacts and look for Copy to sim or something similar. Sim cards have limited memory,varying from 100 to 250 contacts and 30 to 50 sms.Last would be one by one.
Apr 23, 2009 | Cell Phones
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
I've got a Treo 755 with Palm OS and my computer has Windows Vista with Windows Contacts. I am unable to sync the info from my computer to my Treo for all my contacts information. Everyone at the phone...
I have outlook...
but according to the palm manual..
TIP To download a trial version of Microsoft
Outlook and learn about discount offers go to:
http://go.palm.com/treo755p/.
Sep 10, 2008 | Palm M100
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
755 Treo Palm
Have you installed any additional programs? If so, it may be those (the old software/hardware, who's at fault problem). If you have not installed any new programs, or you delete all of them and still have the same problem, Sprint should not give you a hard time replacing the phone.
My phone has some problems with occasional re-starting, but it happens when I run a 3rd party software, so I can't blame that one on Palm/Sprint.
Lee
May 05, 2008 | Palm Treo 755p Smartphone
Beam
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Mar 17, 2008 | Palm Treo 755p Smartphone
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Sep 12, 2005 | Palm Treo 650 Handheld
How do I purge contacts from the Treo 600?
Best would be to perform a hard reset. This will delete all your contacts, but also all your other data on your phone as well such as mail, sms, call log, settings etc.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Sep 11, 2005 | Palm Treo 600 Handheld
    Deleting Outlook contacts
    FileZ file utility lets you delete the AddressDB on your Treo Your best bet would probably be to wipe the Contacts database on your Treo 650, then re-sync. 1. Install FileZ on your Treo 650, Why? Because the Contacts DB is not accessible from the built-in system; you need this extra file manager to delete it. 2. Launch FileZ and find this item: AddressDB. 3. Tap on AddressDB to add a checkmark next to it. Hit Details. Hit Delete. 4. DON'T HOTSYNC YET! Just in case, export your Outlook Contacts and store in a safe place. You'll be syncing to a blank address DB on your 650, and although it shouldn't overwrite your Outlook data wwith the blank DB ... better safe than sorry. 5. Now you can HotSync to Outlook.
    Sep 11, 2005 | Palm Treo 650 Handheld
    Palm Treo 755p Smartphone Logo
    291 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
